- 66
- 2005-5-30
楼主 |
发表于 2009-8-4 03:05:20
来自 江苏南京
Data Matching
Visualize and compare simulation versus target data
Date Updated: 8/3/2009
Version: 3.0.0
Compatibility: Isight 3.5
Platforms: All
Website: data_matching
Bundle: yes
Data Matching is a process in which simulation models are calibrated by minimizing any of a variety of different error measures. The iSIGHT-FD Data Matching component allows target data to be visualized and compared with any simulation results. The target data could be experimental results or simulation results generated by a higher fidelity code.
The Data Matching component provides input support for numerical array parameters generated upstream in the workflow as well as ASCII text file data. It provides output support for numerous error measures including sum of absolute difference, sum of absolute area difference, sum of the squared difference, maximum difference, minimum difference, position of maximum difference, position of minimum difference, and sum of the difference over target. To compute these error measures, the Data Matching component provides automatic data point interpolation so that simulation and target data need not be evaluated at the same dependent variable vector.
Name/Description Last Updated File Size
AdamsDataMatch.avi
Matching Adams results to Excel test data using the MSC.Adams, Excel, and Data Matching components, 5/18/2007, 17.9 mb。
Datamatching_3.0.0.zip
The .jar file for the Data Matching component. This version is compatible with Isight3.5, 7/28/2009, 4.7 mb 。
DataMatching_ComponentSeries.wmv
Data Matching component demonstration from Engineous online development series event recorded on 12/13/2007 ,1/18/2008, 7.0 mb。 |
