- 2007-12-28
楼主 |
发表于 2009-9-23 16:16:47
来自 四川成都
我在现在的工控主板上挂了个硬盘,装上完整版XP,在我的PC上安装VC++ 6.0,MATLAB,再将盘挂到工控主板上。在我的本地,VC 和MATLAB运行正常。移过去后,运行MATLAB出现下面的文字和对话框。
- Illegal instruction detected at Thu Jan 02 06:09:04 2003
- Configuration:
- MATLAB Version: 6.5.0.180913a (R13)
- Operating System: Microsoft Windows XP
- Window System: Version 5.1 (Build 2600: Service Pack 3)
- Processor ID: x86 Family 5 Model 10 Stepping 2, AuthenticAMD
- Virtual Machine: Java 1.3.1_01 with Sun Microsystems Inc. Java HotSpot(TM) Client VM
- (mixed mode)
- Register State:
- EAX = 00000100 EBX = 1410ce38
- ECX = 1410ce00 EDX = 7a0dd318
- ESI = 7a0dd328 EDI = 00000000
- EBP = 00dfdd28 ESP = 00dfdd10
- EIP = 7a09ec7b FLG = 00010246
- Stack Trace:
- [0] hg.dll:_bind_handle_in_table(0x7a0dd318, 0, 0x3f200000, 0x1410ce38) + 43 bytes
- [1] hg.dll:_bind_integer_handle_in_table(0x7a0dd328, 0x1410ce38, 0, 0x014d1088) + 105 bytes
- [2] hg.dll:_assign_figure_handle(0x1410ce38, 0, 0x1410ce38, 23) + 48 bytes
- [3] hg.dll:_create_root_object(4194304, 0, 271244, 1) + 197 bytes
- [4] matlab.exe:_WinMainCRTStartup(3276852, 3342386, 0x7ffde000, 0x8054c6b8) + 308 bytes
- [5] kernel32.dll:0x7c817067(0x0047172c, 0, 0, 0)
- Please follow these steps in reporting this problem to The MathWorks so
- that we have the best chance of correcting it:
- 1. Send this crash report to segv@mathworks.com for automated analysis.
- For your convenience, this information has been recorded in:
- C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\matlab_crash_dump.464
- 2. Also, if the problem is reproducible, send the crash report to
- support@mathworks.com along with:
- - A specific list of steps that will reproduce the problem
- - Any M, MEX, MDL or other files required to reproduce the problem
- - Any error messages displayed prior to this crash report
- A technical support engineer will contact you with further information.
- Thank you for your assistance. Please save your workspace and restart
- MATLAB before continuing your work.
复制代码
由于我在VC的定制里也选了add-in MATLAB 所以打开VC后也会有这个对话框 。
上图也是在打开vc后出现的,不知道有没有遇到类似问题的朋友。这些现象是否能够弥补?
由于是盗版MATLAB都不好意思找mathworks。:L |
