- 2008-10-16
WARNING: The corrector has not converged after 1 attempts. No. of iterations = 6.
ERROR: The simulation stopped at time = 7.05140E-06 . ADAMS cannot solve
the equations of motion.
The greatest error in an equation is 4652.8 in the
equation for CONTACT MODEL_1.Contact1_33 .
The greatest change in a variable is 4652.8 in the
variable for CONTACT MODEL_1.Contact1_33 .
Try the following in this order:
1. Use the MAXIT argument on the EQUILIBRIUM, IC, KINEMATICS,
or INTEGRATOR command to increase the maximum number of
iterations.
2. Temporarily change the value of the PATTERN argument on the
EQUILIBRIUM, IC, KINEMATICS, or INTEGRATOR command to
PATTERN = T.
3. Temporarily increase the value of the ERROR argument on the
EQUILIBRIUM, IC, KINEMATICS, or INTEGRATOR command at
4. If one or more forces change rapidly or sharply near
time = 7.05140E-06, modify the force or forces.
ERROR: Simulation failure detected |
