查看: 118|回复: 5
如何赋流体和固体的属性
发表于 2009-8-30 13:58:30 | 显示全部楼层 |阅读模式 来自 黑龙江哈尔滨
同时存在流体和固体时,固体的属性可以通过指定区域赋予材料属性,流体怎么指定属性呢?就是说定义了流体的属性,但不知道是赋给哪一部分的!
 楼主| 发表于 2009-8-31 10:56:31 | 显示全部楼层 来自 黑龙江哈尔滨
帮帮忙呀!
发表于 2009-8-31 19:03:49 | 显示全部楼层 来自 湖北武汉
你可以通过定义表格的方式,然后把表格赋予材料某一属性,在计算的过程中就可以自动插值.
 楼主| 发表于 2009-8-31 20:37:27 | 显示全部楼层 来自 黑龙江哈尔滨
不明白!3# chenyinqiang 其实我想问的是FLDATA1,SOLU,TRAN,1
FLDATA1,SOLU,FLOW,1
FLDATA1,SOLU,TEMP,0
FLDATA1,SOLU,TURB,0
FLDATA1,SOLU,COMP,0
FLDATA1,SOLU,VOF,0
FLDATA1,SOLU,SFTS,0
FLDATA1,SOLU,IVSH,0
FLDATA1,SOLU,SWRL,0
FLDATA1,SOLU,SPEC,0
FLDATA1,SOLU,ALE,1
FLDATA1,SOLU,RDSF,1
FLDATA12,PROP,DENS,0
FLDATA13,VARY,DENS,0
FLDATA12,PROP,VISC,0
FLDATA13,VARY,VISC,0
FLDATA12,PROP,COND,0
FLDATA13,VARY,COND,0
FLDATA12,PROP,SPHT,0
FLDATA13,VARY,SPHT,0
FLDATA7,PROT,DENS,CONSTANT
FLDATA8,NOMI,DENS,1000,
FLDATA9,COF1,DENS,0
FLDATA10,COF2,DENS,0
FLDATA11,COF3,DENS,0
FLDATA7,PROT,VISC,CONSTANT
FLDATA8,NOMI,VISC,1e-3,
FLDATA9,COF1,VISC,0
FLDATA10,COF2,VISC,0
FLDATA11,COF3,VISC,0
FLDATA12,PROP,IVIS
FLDATA7,PROT,COND,CONSTANT
FLDATA8,NOMI,COND,-1,
FLDATA9,COF1,COND,0
FLDATA10,COF2,COND,0
FLDATA11,COF3,COND,0
FLDATA7,PROT,SPHT,CONSTANT
FLDATA8,NOMI,SPHT,-1,
FLDATA9,COF1,SPHT,0
FLDATA10,COF2,SPHT,0
FLDATA11,COF3,SPHT,0
FLDATA15,PRES,REFE,101350,
FLDATA16,BULK,BETA,36,
FLDATA17,GAMM,COMP,1.4,
FLDATA14,TEMP,NOMI,293,
FLDATA14,TEMP,TTOT,293,
FLDATA14,TEMP,BULK,293,
TOFFSET,0,
FLDATA4,TIME,STEP,0.001,
FLDATA4,TIME,ISTEP,0
FLDATA4,TIME,NUMB,10,
FLDATA4,TIME,TEND,1.0e06
FLDATA4,TIME,GLOB,15,
FLDATA4,TIME,VX,0.01,
FLDATA4,TIME,VY,0.01,
FLDATA4,TIME,VZ,0.01,
FLDATA4,TIME,PRES,1e-004,
FLDATA4,TIME,TEMP,1e-006,
FLDATA4,TIME,ENKE,0.01,
FLDATA4,TIME,ENDS,0.01,
FLDATA4A,STEP,OVER,0,
FLDATA4,TIME,OVER,0
FLDATA4A,STEP,APPE,0,
FLDATA4,TIME,APPE,1.0e6
FLDATA4A,STEP,SUMF,10,
FLDATA4,TIME,SUMF,1.0e6
FLDATA4,TIME,BC,0
FLDATA4,TIME,TEND,1000000,
怎么知道这一大堆是给具体哪一块附属性!
发表于 2009-9-1 20:00:32 | 显示全部楼层 来自 湖北武汉
对应的命令上都有解释,其实不外乎密度,粘度,比热,导热系数等.
 楼主| 发表于 2009-9-4 19:50:29 | 显示全部楼层 来自 黑龙江哈尔滨
一时糊涂,不过谢谢了
GMT+8, 2024-9-20 23:23 , Processed in 0.049676 second(s), 13 queries , Gzip On, MemCache On.
