- 2003-7-11
发表于 2010-10-16 14:57:34
来自 韩国
我的校验也没通过
baqus Product Install Verification...
Sat Oct 16 15:47:43 2010
Running system requirement checks.
Requirement: Windows Server 2003, Windows XP, Windows Vista, or Windows 7
Product: All Abaqus Products
Status: Pass - Found Microsoft Windows XP Professional Service Pack
3 (Build 2600) (x86).
Requirement: Microsoft Visual C++ 9.0 (2008), or 10.0 (2010)
Product: Abaqus make utility with C++
Status: Fail - Unable to locate or determine the version of a C++
compiler on this system. If Microsoft Visual C++ 8.0 (.NET
2005) is installed on this system, please load the
vcvars32.bat file before running Abaqus.
Requirement: Intel Fortran Compiler 10.1 or 11.1
Product: Abaqus make utility with Fortran and Abaqus with user
subroutines
Status: Fail - Found Intel Fortran Compiler 9.0 Build 20050912Z
Package ID W_FC_C_9.0.024.
Requirement: HP-MPI 01.01.00.00
Product: Abaqus analyses using MPI-based parallelization and
Abaqus/CFD
Status: Pass - Found HP-MPI 01.01.00.00.
Requirement: Internet Explorer 6.0 or 7.0 or 8.0, Firefox 2.0 or 3.0 or
3.5, or greater
Product: Abaqus Documentation
Status: Pass - Found Internet Explorer 6.0.2900.5512
Making c:\Temp\verify. All verification files will reside in this directory.
Abaqus/Standard
...PASS
Continuing...
Abaqus/Standard with user subroutines
...INFORMATION
System requirements were not met. Verification
procedure will be skipped. However, user subroutines
can be run using a precompiled library set by the
variable usub_lib_dir. For more information please
see the section 3.2.2 of Abaqus Analysis User's
Manual.
Continuing...
Abaqus/Explicit (single precision)
...PASS
Continuing...
Abaqus/Explicit (double precision)
...PASS
Continuing...
Abaqus/Explicit with user subroutines (single precision)
...INFORMATION
Manual.
Continuing...
Abaqus/Explicit with user subroutines (double precision)
...INFORMATION
Manual.
Continuing...
Abaqus/Viewer
...PASS
Continuing...
Abaqus/CAE
...PASS
Continuing...
Geometry Translator for CATIA V4
...INFORMATION
Product is not licensed. Verification procedure will
be skipped.
Continuing...
Geometry Translator for CATIA V5
...INFORMATION
be skipped.
Continuing...
Direct Geometry Import for CATIA V5
...INFORMATION
be skipped.
Continuing...
Geometry Translator for I-DEAS
...INFORMATION
be skipped.
Continuing...
Geometry Translator for Parasolid
...INFORMATION
be skipped.
Continuing...
Geometry Translator for Pro/ENGINEER
...INFORMATION
be skipped.
Continuing...
SolidWorks Associative Interface
...INFORMATION
be skipped.
Continuing...
Abaqus/AMS
...INFORMATION
be skipped.
Continuing...
Abaqus Interface for MSC.ADAMS
...INFORMATION
be skipped.
Continuing...
Abaqus/Standard parametric studies
...PASS
Continuing...
Abaqus/Explicit parametric studies
...PASS
Continuing...
Abaqus/Design
...INFORMATION
be skipped.
Continuing...
Abaqus Interface for Moldflow
...INFORMATION
be skipped.
Continuing...
...INFORMATION
Continuing...
...INFORMATION
Continuing...
Abaqus make utility with object code
...INFORMATION
Continuing...
Abaqus scripting interface
...PASS
Continuing...
Abaqus analyses using parallelization
...INFORMATION
be skipped.
Continuing...
Abaqus/Foundation
...PASS
Continuing...
Abaqus noGUI (CAE/Viewer)
...PASS
Continuing...
Abaqus/CFD
...PASS
Continuing...
Clean-up...
Verification directory c:\Temp\verify has been deleted. |
