- 2010-9-15
发表于 2011-5-6 14:39:53
来自 江苏南京
这个问题看来只能责怪catia不给力了,要想实现参数的相互传递,必须得装上两个插件。这两个插件基本上想在网上淘到有点不太可能。即使淘到还需在cad configuration manager 设置一下。详情请看
Reader for CATIA V5 (optional) (CADNexus CAPRI CAE Gateway)
This reader requires the following to be installed on the machine:
Compatible version of CATIA V5 CAD program.
Compatible version of CADNexus/CAPRI Gateway V3.08.2.
IBM LUM 4.6.8 configured with a CATIA V5 (MD2, HD2, or ME2) license.
Supports CAD Associativity.
Supports transfer of CAD parameters.
Supports transfer of Layers as named Selections.
Supports transfer of Publications as Named Selections.
Supports transfer of Publications as Attributes.
Allows CATIA V5 file saving with updated CAD parameters.
Supports .CATPart, .CATProduct files.
Supports Solid, Surface, Line bodies.
This is an associative reader. There will be no ANSYS pull-down menu in the CATIA program. It is not possible to update from the Active CAD file in CATIA V5. |
