- 10
- 2007-10-5
If we are using tool list (TEXT) output we need to look at shop_doc.dat. The
tcl file and tpl file to modify are listed here
Tool List (TEXT), ${UGII_CAM_SHOP_DOC_DIR}tool_list.tcl,
${UGII_CAM_SHOP_DOC_DIR}tool_list.tpl
Open tool_list.tcl - the proc that we will be modifying is
proc MOM_TOOL_BODY {} {
global mom_tool_name
global mom_tool_type
global mom_template_subtype
global mom_tool_diameter
global mom_tool_nose_radius
global mom_tool_length_adjust_register
global mom_tool_orientation
global mom_tool_corner1_radius
global mom_tool_point_angle
global mom_tool_flute_length
global setup_header
global tool_head
global Tool_No
global mom_drive_point_diameter
global mom_tool_ug_type
global mom_tool_description
MapToolType tool_type
if {$setup_header > 1} \
if { [string compare $tool_head $tool_type] } { return }
if { $mom_template_subtype == "" } { set mom_template_subtype
$mom_tool_type }
switch $tool_head \
"DRILL" {
set pi [expr 2 * asin(1.0)]
set mom_tool_point_angle [expr [expr 180 / $pi] * \
$mom_tool_point_angle]
set output [format "%-20s %-30s %-10.4f %-10.4f %-10.4f
%-10d\n" \
$mom_tool_name $mom_tool_description \
$mom_tool_diameter $mom_tool_point_angle \
$mom_tool_flute_length $mom_tool_length_adjust_register]
MOM_output_literal "$output"
"MILL" {
# user defined tool. mom_tool_diameter is
if { $mom_tool_ug_type == 15 } {
if {[info exists mom_drive_point_diameter]} {
set mom_tool_diameter $mom_drive_point_diameter
%-10d\n" \
$mom_tool_name $mom_tool_description\
$mom_tool_diameter $mom_tool_corner1_radius \
"LATHE" {
set tool_orient [expr [expr 180 / 3.14] * \
$mom_tool_orientation]
set output [format "%-20s %-30s %-10.4f %-15.4f %-10d\n" \
$mom_tool_nose_radius $tool_orient \
} else \
switch $tool_type \
"MILL" { incr Tool_No(mill) }
"DRILL" { incr Tool_No(drill) }
"LATHE" { incr Tool_No(lathe) }
For our example if we want to add tool lenth to the Drills, you will add
mom_tool_length to the global list
then modify the format statement under the "DRILL" case to look like this
"DRILL" {
%-10.4f %-10d\n" \
Notice we added the tool length after the tool flute length. This meant we had
to add the %-10.4f in the format statement and the $mom_tool_length |
