- 7
- 2002-9-10
发表于 2009-10-25 06:37:12
来自 山东淄博
进一步验证求解结果,共绘制6条线(如图中所标注),基本代码:
- !const["pi",acos(0)*2,1];
- !const["r",pi/2-0.6685,1];
- f(fai::t)=1/16*(-2932650*cos(1/2*t-fai-r)*pi^2+2932650*cos(-fai-r+3/2*t)*pi^2+1857345*cos(-fai-r+t)*pi^2-1857345*cos(2*t-fai-r)*pi^2-3870720*fai*sin(-fai-r+t)+3677184*fai*sin(-fai-r+3/2*t))/pi^2;
- _x(_t:fai:t)= t=_t,fai=100,XSLSF::pqrt(HFor("f"),&fai,1e-6),105*cos(t-fai-r)-133/2*cos(3/2*t -fai-r); //黑色
- _y(_t:fai:t)= t=_t,fai=100,XSLSF::pqrt(HFor("f"),&fai,1e-6),105*sin(t-fai-r)-133/2*sin(3/2*t -fai-r); //红色
- _z(_t:fai:t)= t=_t,fai=100,XSLSF::pqrt(HFor("f"),&fai,1e-6),96*fai/(2*pi); //蓝色
- _R(_t:fai:t)= t=_t,fai=100,XSLSF::pqrt(HFor("f"),&fai,1e-6),((105*sin(-fai-r+t)-133/2*sin(-fai-r+3/2*t))^2+2304*fai^2/pi^2)^(1/2); //绿色
- _fai(_t:fai,i:t)=
- t=_t,fai=100,
- i=XSLSF::pqrt(HFor("f"),&fai,1e-6),
- if{i==10,printff{"已迭代{1,i}10次,但未满足精度要求,返回值仅作参考。fai={2,r}\r\n",i,fai}},
- fai
- 误差(fai,t)=1/16*(-2932650*cos(1/2*t-fai-r)*pi^2+2932650*cos(-fai-r+3/2*t)*pi^2+1857345*cos(-fai-r+t)*pi^2-1857345*cos(2*t-fai-r)*pi^2-3870720*fai*sin(-fai-r+t)+3677184*fai*sin(-fai-r+3/2*t))/pi^2;
- _误差(_t:fai,x:t)=
- t=_t,fai=100,
- XSLSF::pqrt(HFor("f"),&fai,1e-6),
- x=误差(fai,t),
- if{abs(x)>1e-6,printff{"t={1,r}时,fai={2,r},误差={3,r}\r\n",t,fai,x}},
- x
复制代码
完整的FcCurve文件如下:
- FCC文件
- 缺省设置:
- (XNote=请修改为X轴单位) (YNote=请修改为Y轴单位)
- (AutoY=1) (XMin=0) (XMax=1) (YMin=0) (YMax=1)
- (BorderPixels=60) (MultiplyX=1) (MultiplyY=1) (Grid=0) (DivideXY=10) (XYNumWidth=3) (DataMax=2)
- (ForMax=50) (LoadDll=)
- [CODE]
- // 通用设置:
- // (XNote=x:黑色;y:红色;z蓝色;R:绿色;fai:浅蓝色;误差:棕色) (YNote=请修改为Y轴单位)
- // (AutoY=1) (XMin=0.6352) (XMax=1.4259) (YMin=-20) (YMax=200)
- // (BorderPixels=80) (MultiplyX=1) (MultiplyY=1) (Grid=0) (DivideXY=10) (XYNumWidth=3) (DataMax=2)
- // (ForMax=50) (LoadDll="dll\FcData32W" "dll\XSLSF32W" ) (DotColor=0) (DotSize=10)
- /*[LINE]
- (_x=0,1000,0,0,0)
- (_y=0,1000,0,0,8388863)
- (_z=0,1000,0,0,16711680)
- (_R=0,1000,0,0,4259584)
- (_fai=0,1000,0,0,16776960)
- (_误差=1,1000,0,0,128)
- [LEND]*/
- // [BODY]
- _fai(_t:fai,i:t)=
- t=_t,fai=100,
- fai
- _误差(_t:fai,x:t)=
- t=_t,fai=100,
- x=误差(fai,t),
- x
复制代码
以上代码保存为任意文本文件,用FcCurve打开即可。
FcCurve下载:http://xoomer.virgilio.it/forcal/xiazai/forcal9/fccurve.rar
误差函数“误差(fai,t)”在-1.8e-8~1.8e-8之间,如图:
