查看: 77|回复: 1
[Flex及相关] 请教仿真时出现的 ADAMS MEMORY OVERFLOW问题
发表于 2009-12-11 16:00:48 | 显示全部楼层 |阅读模式 来自 广东佛山
大家好,我做了个N段小圆柱(每段50mm长)用bushing连接起来模拟钢丝绳的仿真,由于钢丝绳要求比较长有50m左右,因此仿真出现 :
A larger MD array is required.
Several off-the-shelf memory configurations are available and
custom configurations may be created.
The available memory models
and the corresponding array sizes are:
NAME
MDSIZ
STANDARD
1,100,000
LARGE
3,000,000
EX-LARGE
10,000,000
HUGE
20,000,000
where MDSIZ is the size in words (one word is 4 bytes) of the MD array,
the main memory array in ADAMS in words (one word is 4 bytes).
To use an alternative setting do the following:
-Bring up the ADAMS application bar;
-Right click on Solver and select "Change ADAMS/Solver Settings";
-Click on memSize and select from the four pre-built models;
-Commit your changes.
If you are running Solver from within ADAMS/View select
"Change ADAMS/View Settings" from the ADAMS application bar.
Refer to Chapter 4, of "Running and Configuring ADAMS"
or for additional details and for creating custom memory models.
ERROR:
Abnormal termination encountered in ADAMS/Solver.
我把钢丝绳全部删掉,仿真就没问题了,但是做的仿真要求钢丝绳越长越好,我按上述要求把solve中的内存改为huge,还是有问题;最后把每段钢丝绳长度由50mm改为80mm,把钢丝绳总长度由50m改为35m,还是太长了,计算量太大总是出现上述问题,请问大家有什么好的建议解决这个问题了,在此谢谢大家。
发表于 2009-12-11 21:18:07 | 显示全部楼层 来自 北京海淀
GMT+8, 2024-11-1 23:36 , Processed in 0.031356 second(s), 13 queries , Gzip On, MemCache On.
