- 2009-5-1
向大家请教个问题,如何输出螺栓中预拉面上的合力(total force across the pre-tension section)。根据abaqus analysis user's manual 19.5.1中的提示在历史变量输出编辑框中将domain设为 boltload ,然后选中forces/reactions中的 TF。在dat文件出现了下述错误,不知道什么地方出错了,向大家请教。
**ERROR: in keyword *NODEOUTPUT, file "CJE1-1J.inp", line 61291: Unknown part
instance set BOLT-MESH-1-1._BOLTLOAD1_BLRN_
***NOTE: DUE TO AN INPUT ERROR THE ANALYSIS PRE-PROCESSOR HAS BEEN UNABLE TO
INTERPRET SOME DATA. SUBSEQUENT ERRORS MAY BE CAUSED BY THIS OMISSION
***ERROR: in keyword *NODEOUTPUT, file "CJE1-1J.inp", line 61296: Unknown part
instance set BOLT-MESH-2-1._BOLTLOAD2_BLRN_
***ERROR: in keyword *NODEOUTPUT, file "CJE1-1J.inp", line 61467: Unknown part
instance set BOLT-MESH-4-1._BOLTLOAD4_BLRN_ |
