计算流体时,出现这样的问题,不知道那位大虾见过,请指点“poto is not a valid DOF/variable for this solution
USE flda,outp commamd to add DOF/variable to the results
file for postprocessing.”
点“last set”,提示“cumulation iteration 0 may have been solved using different model or boundary condition data than currently stored. POST1 results may be erroneous unless you resume from a jobname.db file for this substep.” 谢谢指点。
