楼主: zzhbjtu
[学术与经验交流] 可以查材料疲劳特性曲线的网站
发表于 2010-6-12 12:24:24 | 显示全部楼层 来自 美国
没有图啊。
发表于 2010-6-12 17:10:38 | 显示全部楼层 来自 陕西西安
我怎么登陆不上去呢??
发表于 2010-6-12 17:17:01 | 显示全部楼层 来自 陕西西安
不好意思,写错一个单词,应该是下面的地址:
0 s  X3 B% A' q) \  c  O6 iwww.wm.tu-darmstadt.de/mat-db-html/index.html) W9 z+ l# V0 {6 _2 I" |
zzhbjtu 发表于 2010-2-5 17:32
9 r7 l$ d+ ]' N! z, e( S
+ D9 c, G) W7 v# l2 l
% [! Z. Y( f& D1 A. W5 O没仔细看帖子。
发表于 2010-6-16 14:56:39 | 显示全部楼层 来自 浙江杭州
14# fuga
& C1 X' D, w  @+ v7 G
) I) V& {* F9 N5 O2 `: i方框右下方,有个绿色的“view”,点击进入。可以看到如下数据(曲线的话,点击了好像看不到,不过有下面的数据的话,可以在疲劳分析软件比如nsoft得到曲线):: q* l! G6 o3 w! e0 c
Ck 45 1.1191
Heat treatment: 870°C/30min/close annealed
Test temperature: 23°C
Semifinished Material: bar, diameter 20 mm
Reference: Reik W., Mayr P., Macherauch E., |2.6|
Year: 1973 - 1978
Chemical composition 7 j. H( ?7 I% l4 g
C Si Mn P S Cr Mo Ni V
0.48 0.28 0.77 0.021 0.033 0.18 0.03 0.07 0.02
Microstructure
grainsize of ferrite ~6 micrometer
Monotonic test
Loading Condition:
Specimen: cylindrical, diameter 3.8 mm
Specimen location: in and diametral to rolling direction
Gauge length: 60 mm
Testing maschine:
Strain rate: 1.8%/minute
Constant amplitude test
Loading condition: total strain control, strain ratio = -1
Specimen: cylindrical, diameter 10 mm
Surface: grinded, roughness 1 micrometer
Gauge length: 25 mm
Testing maschine: Schenck, servohydraulic, 60 kN
Frequency: 4 - 8 Hz
Strain rate:
Waveform: triangular
Failure criterion: macroscopical crack initiation
σ/ε-values valid for: half failure life
Hardness
Monotonic Properties
E
210000 N/mm²
Rp0.2
415.0N/mm²
Rm
680.0N/mm²
A5
19.0%
Z
ν
K
413.000N/mm²
n
0.0010-
σf
N/mm²
εf
Cyclic Properties
R′p0.2
349N/mm²
σE
N/mm²
εE
NE
cycles
NT
9082cycles
Tσ
1.192-
Tεp
6.244-
K′
808N/mm²
n′
0.135-
σ′f
2621N/mm²
ε′f
47000.000-
b
-0.210-
c
-1.753-
Incremental step test
Remarks
Youngs modulus estimated7 c( |7 F3 n6 p& O. M+ Z
no significant influence of test results for specimen location in or diametral to rolling direction
K′
N/mm²
n′
Stress-Strain-CurveStrain-Life-CurvePSWT-Life-Curve
spec.! N. ]2 X: X; `! l/ [. S" C$ |
no.
εa4 J! _9 U6 T5 Q& Z
σa+ D) E/ C: o2 i# b  r% R
N/mm²
σm
3 e% h) \! f0 R4 T: Q" ~& D% EN/mm²
N5 w7 i' \( w6 j1 ~# e/ T* o! |
cycles
60.358352.80638750.322339.80941240.243310.901546920.138253.902069130.168276.103200810.115225053899
发表于 2010-6-17 07:33:31 | 显示全部楼层 来自 上海嘉定区
感谢楼上了,呵呵,原来如此
发表于 2010-7-19 10:22:32 | 显示全部楼层 来自 清华大学
好像点击view,要交钱啊
发表于 2010-8-1 14:33:22 | 显示全部楼层 来自 天津
lz啊,咱的登录密码是多少啊,没有看到你的第一张图啊,guest,
发表于 2010-8-3 12:05:49 | 显示全部楼层 来自 江苏南京
对于搞岩土的值得去好好学习 谢谢楼主
发表于 2010-8-4 11:19:20 | 显示全部楼层 来自 陕西西安
继续解释一下啊
发表于 2010-8-8 10:22:14 | 显示全部楼层 来自 河北
可以查阅疲劳曲线,但都是常温的。哪有高温的疲劳曲线?
发表于 2010-8-8 11:53:01 | 显示全部楼层 来自 江苏镇江
8 T8 v$ F: O1 u& H7 r
1 T$ B, L! X. N5 [2 Z 14# fuga ! p. e) D; [$ o9 Q
楼主强大。可以找的
6 i# o! J5 d2 |' g: a" o; D$ o0 j; `1点右下角的View
0 R1 e: p3 S' ~" v9 x- ?# O6 f3 q3 P/ v# ]. d; s- j: x( c
2最下边有三个选项1 \. n8 Q: ?) N8 |! q
, U6 [( s4 d' T8 S1 y4 Z. |/ D$ m3这应该,就是了把
  v2 N4 C6 w7 ]& c+ [6 v
发表于 2010-8-8 11:59:36 | 显示全部楼层 来自 江苏镇江
本帖最后由 wanghongyu 于 2010-8-8 12:01 编辑 8 {; K+ A  E/ i! [3 \& J
& Y, T* l& O; F* K- r$ v 13# zzhbjtu # w+ K# L, C2 T" Z4 }& t. n
请教,这有三个曲线,最后那个是不是S-N,曲线啊,怎么用PSWT表示的啊?是不是用水压力表示的应力啊,看那单位也是应力的单位
% V# y2 {  P$ `8 \" \
, l. X$ G) V$ F6 W& P, V1 v" E% a
7 h' |% C. ]% Z5 v& x( s. j
发表于 2011-3-8 13:57:13 | 显示全部楼层 来自 浙江杭州
32# wanghongyu
0 z! K  k& Q9 S- R( W# m你好!7 F4 V: a/ [2 l9 ^9 S! K3 a
我不能产生这三个曲线,你能帮我生成GGG60的曲线吗?
发表于 2011-3-10 14:28:11 | 显示全部楼层 来自 上海南汇区
今天才看到这个帖子,也许这个问题已经解决了吧,只要点击右下角的蓝色字体的VIEW就可以了,打开的页面中有材料的循环特性参数。应该有曲线的,只是那个页面我打开时是空白的,我也很纳闷。关键的问题是:man-ten代表什么材料呢?我想知道Q345的循环特性参数,请高手明示呀!!
发表于 2011-3-22 10:38:00 | 显示全部楼层 来自 陕西西安
楼主详细说明一下吧,查那个表之后怎么办
发表于 2011-3-22 10:41:02 | 显示全部楼层 来自 陕西西安
怎样出来曲线?哪位说明一下,多谢了!
发表于 2011-3-22 10:45:03 | 显示全部楼层 来自 陕西西安
我的没有view这个选项
发表于 2012-1-24 18:48:07 | 显示全部楼层 来自 广东深圳
2 u) y/ }$ x% r% Z) z3 u! P
谢谢楼主分享,已经注册,可以查询了
发表于 2012-1-30 11:29:01 | 显示全部楼层 来自 香港
wanghongyu 发表于 2010-8-8 11:59 + B4 D! Q% @: w& ]" B5 D
13# zzhbjtu
0 B5 J" b! j0 `# Y% K请教,这有三个曲线,最后那个是不是S-N,曲线啊,怎么用PSWT表示的啊?是不是用水压力表示 ...
1 a( S# n* x; h6 \" k/ v/ m就是S-N 了
% _* M, X" b' k: c  ]: ^# Q: G1 X6 k) [* h0 ]5 o  H2 L  X
SWT (Smith-Watson-Topper) 是 疲劳 一种计算的方法
发表于 2012-1-31 11:11:59 | 显示全部楼层 来自 上海
查不出来啊,给了经常用的材料名字,没搜出东西来
GMT+8, 2026-1-10 10:56 , Processed in 0.035277 second(s), 7 queries , Gzip On, MemCache On.
