查看: 61|回复: 0
焊接模拟H型钢出现了问题,附命令流,期待高手出现。
发表于 2010-4-25 13:32:12 | 显示全部楼层 |阅读模式 来自 合肥工业大学
我的焊接模拟H型钢焊接过程,生成温度和应力动画,想做三维的模拟,但是例子太少,先做了二维的,可是运行的时候老师说调用结果文件 file.rst出错,我也不知道什么地方有错误,期待高手出现。
fini
/clear
/title, Weld Analysis by "Element Birth and Death"
/prep7
/unit,si
et,1,13,4
et,2,13,4
mptemp,1,20,500,800,1200,1500
mpdata,ex,1,,2.09e11,1.72e11,1.33e11,0.84e11,0.45e11
mpdata,ex,2,,2.16e11,1.78e11,1.42e11,1.04e11,0.68e11
mpdata,ex,3,,2.12e11,1.75e11,1.39e11,1.07e11,0.83e11
tb,bkin,1,5
tbtemp,20,1
tbdata,1,315e6,0.209e11
tbtemp,500,2
tbdata,1,212e6,0.172e11
tbtemp,800,3
tbdata,1,153e6,0.133e11
tbtemp,1200,4
tbdata,1,93e6,0.084e11
tbtemp,1500,5
tbdata,1,33e6,0.045e11
tb,bkin,2,5
tbtemp,20,1
tbdata,1,314e6,0.216e11
tbtemp,500,2
tbdata,1,203e6,0.178e11
tbtemp,800,3
tbdata,1,153e6,0.142e11
tbtemp,1200,4
tbdata,1,63e6,0.104e11
tbtemp,1500,5
tbdata,1,13e6,0.068e11
tb,bkin,3,5
tbtemp,20,1
tbdata,1,330e6,0.212e11
tbtemp,500,2
tbdata,1,213e6,0.175e11
tbtemp,800,3
tbdata,1,153e6,0.139e11
tbtemp,1200,4
tbdata,1,73e6,0.107e11
tbtemp,1500,5
tbdata,1,13e6,0.083e11
mp,dens,1,7850
mp,dens,2,7770
mp,dens,3,7860
mp,alpx,1,1.23e-5
mp,alpx,2,1.38e-5
mp,alpx,3,1.48e-5
mp,nuxy,1,0.30
mp,nuxy,2,0.29
mp,nuxy,3,0.29
mp,kxx,1,33
mp,kxx,2,32
mp,kxx,3,34
mp,c,1,561
mp,c,2,683
mp,c,3,983
mp,murx,1,1
mp,murx,2,1
mp,murx,3,1
mp,reft,1,20
mp,reft,2,1500
mp,reft,3,20
*afun,deg
csys,0
width=.8
height=0.8
delt1=0.004
deltx=0.04*tan(50)
ar=0.04/sin(45)
br=0.04/sin(40)
k,1,,,
k,2,.08,0,0
k,3,.08,height,0
k,4,0,height,0
k,5,0.08+delt1+deltx,height/2-0.04,0
k,6,.676,height/2-0.04,0
k,7,.676,height/2+0.04,0
k,8,0.08+delt1+deltx,height/2+0.04,0
k,9,0.08+delt1,height/2,0
k,10,.08,height/2+ar,0
k,11,.08,height/2-br,0
k,12,.716,.4,0
k,13,0.72,height/2+ar,0
k,14,.72,height/2-br,0
k,15,.72,0,0
k,16,.8,0,0
k,17,.8,.8,0
k,18,.72,.8,0
larc,10,8,9,ar
larc,11,5,9,br
larc,7,13,12,ar
larc,6,14,12,br
a,1,2,3,4
a,8,10,11,5,9
a,8,9,5,6,12,7
a,6,14,13,7,12
a,18,17,16,15
esize,0.01 !指定网格边长的大
type,2 !!指定单元类型号
mat,2 !指定材料类型参考号
amesh,2 !对焊缝区划分网格
mat,4!指定材料类型参考号
amesh,4 !对焊缝区划分网格
esize,0.03
type,1
mat,1
amesh,1 !对母材区的左面划分网格
mat,3
amesh,3 !对母材区的左面划分网格
mat,5
amesh,5  !对母材区的右面划分网格
nummrg,all,,,,low !合并所有的实体
numcmp,all !压缩所有实体的编号包括节点和单元
eplot
/image,save,vmesh,bmp  !将网格保存为一个位图文件,如图8-10所示
finish
!*************************************施加约束****************************************
/solu
antype,4
trnopt,full
nsel,all
*get,minx,node,,mnloc,x
nsel,s,loc,x,minx
d,all,ux,0
*get,miny,node,,mnloc,y
nsel,r,loc,y,miny
d,all,uy,0
nsel,all
nsel,s,loc,x,minx
d,all,temp,20
nsel,all
*get,maxx,node,,mxloc,x
nsel,s,loc,x,maxx
d,all,temp,20
alls
nna=2
esel,all
*get,emax,elem,,num,max
asel,s,area,,nna
esla
*get,nse,elem,,count
*dim,ne,,nse
*dim,n1,,nse
*dim,n2,,nse
*dim,nex,,nse
*dim,ney,,nse
*dim,neorder,,nse
ii=0
*do,i,1,emax
*if,esel(i),eq,1,then
  ii=ii+1
  ne(ii)=i
*endif
*enddo
*do,i,1,nse
*get,ney(i),elem,ne(i),cent,y
*get,nex(i),elem,ne(i),cent,x
*enddo
d=0
*do,i,1,nse
*if,ney(i),ge,height/2,then
  d=d+1
  n2(d)=ne(i)
*endif
*enddo
c=0
*do,i,1,nse
*if,ney(i),lt,height/2,then
  c=c+1
  n1(c)=ne(i)
*endif
*enddo
esel,none
*do,i,1,d
*if,n2(i),ne,0,then
  esel,a,elem,,n2(i)
*endif
*enddo
eplot
!*************************对焊缝区上部分的单元按质心Y坐标进行排序****************************
mine=0
*dim,ne2,,d
*dim,nex2,,d
*dim,ney2,,d
*do,i1,1,d
esel,u,elem,,mine
*get,nse2,elem,,count
ii=0
*do,i,1,emax
    ii=ii+1
    ne2(ii)=i
  *endif
*enddo
*do,i,1,nse2
  *get,ney2(i),elem,ne2(i),cent,y
  *get,nex2(i),elem,ne2(i),cent,x
*enddo
miny=1e20
minx=1e20
*do,i,1,nse2
  *if,ney2(i),lt,miny,then
   miny=ney2(i)
   minx=nex2(i)
   mine=ne2(i)
  *else
  *if,ney2(i),eq,miny,then
  *if,nex2(i),lt,minx,then
   miny=ney2(i)
   minx=nex2(i)
   mine=ne2(i)
  *endif
  *endif
  *endif
*enddo
neorder(i1)=mine
*enddo
!*********对焊缝区下部分的单元按质心Y坐标进行排序,与其上部分的过程相类似******************
maxe=0
esel,none
*do,j,1,c
*if,n1(j),ne,0,then
  esel,a,elem,,n1(j)
*endif
*enddo
eplot
*dim,ne1,,c
*dim,nex1,,c
*dim,ney1,,c
*do,j1,1,c
esel,u,elem,,maxe
*get,nse3,elem,,count
jj=0
*do,j,1,emax
  *if,esel(j),eq,1,then
    jj=jj+1
    ne1(jj)=j
  *endif
*enddo
*do,j,1,nse3
   *get,ney1(j),elem,ne1(j),cent,y
   *get,nex1(j),elem,ne1(j),cent,x
*enddo
maxy=-1e10
maxx=-1e10
*do,j,1,nse3
  *if,ney1(j),gt,maxy,then
     maxy=ney1(j)
     maxx=nex1(j)
     maxe=ne1(j)
  *else
  *if,ney1(j),eq,maxy,then
  *if,nex1(j),lt,maxx,then
     maxy=ney1(j)
     maxx=nex1(j)
     maxe=ne1(j)
  *endif
  *endif
  *endif
*enddo
neorder(j1+d)=maxe
*enddo
max_tem=1500
delt=1e-3
dt=5
t=0
esel,all
eplot
/auto,1
/replot
*do,i,1,nse
ekill,neorder(i)
esel,s,live
eplot
*enddo
alls
outres,all,all
ic,all,temp,20
kbc,1
timint,0,struct
timint,0,mag
timint,1,therm
tintp,0.005,,,1,0.5,0.2
nsub1=2
nsub2=40
*do,i,1,nse
ealive,neorder(i)
esel,s,live
eplot
esel,all
t=t+delt
time,t
nsubst,1
*do,j,1,4
   d,nelem(neorder(i),j),temp,max_tem
*enddo
solve
t=t+delt
time,t
solve                                           ! 求解
*do,j,1,4
  ddele,nelem(neorder(i),j),temp
*enddo
t=t+dt-2*delt
time,t
nsubst,nsub1
solve
*enddo
t=t+50000
time,t
nsubst,nsub2
solve
finish
!***********************************进入后处理*******************************************************
/post26
nsol,2,379,temp,,temp379
/gropt,axnsc,1.5,
plvar,2
/image,save,temp379,jpeg
finish
!************生成节点Von Mises当量应力云图动画文件的程序段********************************
/post1
/seg,dele
/cont,1,15,0,1200e6/16,1200e6
/dscale,1,1.0
avprin,0,0
avres,1
/seg,multi,stress,0.1
esel,all
*do,i,1,nse
esel,u,elem,,neorder(i)
*enddo
*do,i,1,nse
esel,a,elem,,neorder(i)
set,(i-1)*3+1,1
plnsol,s,eqv
*do,j,1,nsub1
   set,(i-1)*3+3,j
   plnsol,s,eqv
*enddo
*enddo
*do,i,1,nsub2
set,(nse-1)*3+4,i
plnsol,s,eqv
*enddo
/seg,off,stress,0.1
/image,save,stress,jpeg
finish
!************生成节点温度分布云图动画文件的程序段********************************
/post1
/seg,dele
/cont,1,15,0,1500/16,1500
/dscale,1,1.0
avprin,0,0
avres,1
/seg,multi,temp,0.1
esel,all
*do,i,1,nse
*enddo
*do,i,1,nse
set,(i-1)*3+1,1
plnsol,temp
*do,j,1,nsub1
  set,(i-1)*3+3,j
  plnsol,temp
*enddo
*enddo
*do,i,1,nsub2
set,(nse-1)*3+4,i
plnsol,temp
*enddo
/seg,off,temp,0.1
anim,1,1
!***************************** 显示路径上的应力分布结果******************************
set,last
csys,0
path,xdirection,2,10
ppath,1,1
ppath,2,2
pdef,,s,eqv
/gropt,axnsc,1.5,
plpath,seqv
/image,save,xpath,jpeg
path,ydirection,2,10
ppath,1,1
ppath,2,3
pdef,,s,eqv
/gropt,axnsc,1.5
plpath,seqv
/image,save,ypath,jpeg
finish
save
GMT+8, 2024-9-20 19:49 , Processed in 0.027645 second(s), 10 queries , Gzip On, MemCache On.
