- 10
- 2002-10-23
楼主 |
发表于 2003-7-15 23:53:58
来自 加拿大
回复: 【讨论】线性还是非线性?
** MATERIALS
*Material, name=steel
*Elastic
2.06e+08, 0.3
** INTERACTION PROPERTIES
*Surface Interaction, name=nofriction
1.,
*Friction
0.,
*Surface Behavior, pressure-overclosure=HARD
** BOUNDARY CONDITIONS
** Name: pin-a-1 Type: Displacement/Rotation
*Boundary
_PickedSet410, 1, 1
_PickedSet410, 2, 2
_PickedSet410, 3, 3
_PickedSet410, 4, 4
_PickedSet410, 5, 5
_PickedSet410, 6, 6
** Name: pin-a-2 Type: Displacement/Rotation
*Boundary
_PickedSet411, 2, 2
_PickedSet411, 3, 3
_PickedSet411, 4, 4
_PickedSet411, 5, 5
_PickedSet411, 6, 6
** Name: pin-b Type: Displacement/Rotation
*Boundary
_PickedSet412, 3, 3
_PickedSet412, 4, 4
_PickedSet412, 5, 5
_PickedSet412, 6, 6
** Name: symmetry Type: Symmetry/Antisymmetry/Encastre
*Boundary
_PickedSet413, ZSYMM
** INTERACTIONS
** Interaction: pin-a-1
*Contact Pair, interaction=nofriction
_PickedSurf552, pin-a-3.RigidSurface_
** Interaction: pin-a-2
_PickedSurf550, pin-a-4.RigidSurface_
** Interaction: pin-b
_PickedSurf548, pin-b-1.RigidSurface_
** STEP: Step-1
*Step, name=Step-1
equivalent loads
*Static
1., 1., 1e-05, 1.
** LOADS
** Name: Load-1 Type: Concentrated force
*Cload
_PickedSet408, 1, 1000.
** OUTPUT REQUESTS
*Restart, write, frequency=1
** FIELD OUTPUT: F-Output-1
*Output, field, variable=PRESELECT
** HISTORY OUTPUT: H-Output-1
*Output, history, variable=PRESELECT
*El Print, freq=999999
*Node Print, freq=999999
*End Step
** STEP: Step-2
*Step, name=Step-2
*Static
1., 1., 1e-05, 1.
** LOADS
*Cload, op=NEW
** Name: Load-2 Type: Concentrated force
*Cload, op=NEW
_PickedSet731, 1, 1000.
** OUTPUT REQUESTS
*End Step
** STEP: Step-3
*Step, name=Step-3
*Static
1., 1., 1e-05, 1.
** LOADS
*Cload, op=NEW
** Name: Load-3 Type: Concentrated force
*Cload, op=NEW
_PickedSet731, 2, -1000.
** OUTPUT REQUESTS
*End Step |
