以下是命令流,但是总是只有第一层循环的最后一个值被执行
望高手帮忙看一下
FINISH
/CLEAR
/TITLE,CONTACT ANALYSIS OF WARPED WAFER AND WAFER CHUCK
/PREP7
/NERR,0
/UIS,MSGPOP,3
/PAGE,99999,132,99999,240
/HEADER,ON,ON,ON,ON,ON,ON
/FORMAT,7,G,17,9,99999
!F1 = 0.70836801704
!PRES = 0.101
ET,1,PLANE182
ET,2,TARGE169
ET,3,CONTA171
KEYOPT,1,3,2
KEYOPT,3,1,0
KEYOPT,3,2,0
KEYOPT,3,3,0
KEYOPT,3,4,0
KEYOPT,3,5,1
KEYOPT,3,6,0
KEYOPT,3,7,0
KEYOPT,3,8,0
KEYOPT,3,9,0
KEYOPT,3,10,2
KEYOPT,3,11,0
KEYOPT,3,12,0
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,EX,1,,165700
MPDATA,PRXY,1,,0.28
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,MU,1,,0.1
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,EX,2,,363000
MPDATA,PRXY,2,,0.23
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,MU,2,,0.1
R,1,,,20,
!建立模型
K,1,-100,0.3875
K,2,100,0.3875
K,3,100,-0.3875
K,4,-100,-0.3875
L,1,2
L,2,3
L,3,4
L,4,1
AL,ALL
K,5,-110,-0.3875
K,6,110,-0.3875
K,7,110,-10
K,8,-110,-10
L,5,6
L,6,7
L,7,8
L,8,5
AL,5,6,7,8
!网格划分
MAT,1
TYPE,1
LESIZE,1, , ,1000, , , , ,1
LESIZE,3, , ,1000, , , , ,1
LESIZE,2, , ,4, , , , ,1
LESIZE,4, , ,4, , , , ,1
AMESH,1
ALLSEL
MAT,2
TYPE,1
SMRTSIZE,5
AMESH,2
ALLSEL
LSEL,S,LINE,,5
NSLL,S,1
TYPE,2
REAL,1
ESURF
ALLSEL
LSEL,S,LINE,,3
NSLL,S,1
REAL,1
TYPE,3
ESURF
ALLSEL
!施加边界条件,施加载荷,求解
*DO,F1,0.708,0.71,0.001
/CLEAR
SECOND,F1
*ENDDO
SECOND
*DO,PRE,0.061,0.056,-0.005
!大气压力作用
/SOLU
ANTYPE,STATIC,NEW
TIME,1
!设置对称
LSEL,S,LINE, ,5
NSLL,S,1
D,ALL,ALL,0
ALLSEL
NSEL,S,NODE,,3507
D,ALL,UX,0
!设置压力作用范围及大小
ALLSEL
LSEL,S,,,3
NSLL,S,1
CM,PRESSURE,NODE
SF,PRESSURE,PRES,-PRE
!求解
ALLSEL
ANTYPE,0
NLGEOM,1
SOLVE
*CFopen,'D:\ANSYS_WAFER_SIMULATION\Wafer Test Result201005312122_MACRO\MAXDEFORMATION','txt', ,APPEND
*VWRITE,ARG1,PRE
(F6.3,F6.3)
*VWRITE
('第一次求解完成')
*CFclos
!弯曲作用力作用
/SOLU
ANTYPE,STATIC,REST
*VWRITE,ARG1,PRE
(F6.3,F6.3)
*VWRITE
('第二次求解开始')
TIME,2
*VWRITE,ARG1,PRE
(F6.3,F6.3)
*VWRITE
('设置作用力')
!设置作用力
NSEL,S,NODE, ,1002
D,ALL,UY,0
F,ALL,FX,-ARG1
ALLSEL
*VWRITE,ARG1,PRE
(F6.3,F6.3)
*VWRITE
('设置作用力')
NSEL,S,NODE, ,1006
D,ALL,UY,0
F,ALL,FX,ARG1
!求解
ALLSEL
NLGEOM,1
SOLVE
*VWRITE,ARG1,PRE
(F6.3,F6.3)
*VWRITE
('第二次求解完成')
*CFclos
FINISH
!获取计算结果
ND=1
*DEL,NODES,,NOPR
*DEL,XYZ,,NOPR
*DEL,MAXVALUE,,NOPR
*DIM,NODES,ARRAY,1001
*DIM,XYZ,ARRAY,1001,3
*DO,I,1,1001,1
NODES(I)=ND
XYZ(I,2)=UY(ND)
ND=ND+1
*ENDDO
MAXVALUE = XYZ(1,2)
*DO,I,2,1001,1
*IF,MAXVALUE,LT,XYZ(I,2),THEN
MAXVALUE = XYZ(I,2)
*ENDIF
*ENDDO
MAX2=MAXVALUE-0.000013
*IF,MAX2,GT,0,THEN
*VWRITE,ARG1,PRE,MAXVALUE
(F6.3,F6.3,F18.15)
*CFclos
*ENDIF
*ENDDO
FINISH
/EOF |
