楼主: rp_no
[流体分析] 昨天写的CFX流固耦合的文档
发表于 2010-7-10 08:11:16 | 显示全部楼层 来自 浙江温州
高深的我可看不懂 是基础的吗呵呵
也非常感谢楼主无私奉献
发表于 2010-7-11 19:36:40 | 显示全部楼层 来自 重庆沙坪坝区
解压的时候要解压分卷,怎么办?
发表于 2010-7-13 09:09:52 | 显示全部楼层 来自 山东东营
谢谢上传,辛苦了
发表于 2010-7-13 11:07:18 | 显示全部楼层 来自 陕西西安
十分感谢。
发表于 2010-7-15 07:20:41 | 显示全部楼层 来自 黑龙江哈尔滨
一直想学习这方面的内容,可总是摸不着头绪,多谢楼主啊!
发表于 2010-7-15 07:23:33 | 显示全部楼层 来自 黑龙江哈尔滨
这个我看了,是原创的,很不错,很详细,感谢楼主
发表于 2010-7-17 14:16:34 | 显示全部楼层 来自 江苏镇江
谢谢分享!
发表于 2010-7-19 11:38:05 | 显示全部楼层 来自 新疆乌鲁木齐
楼主,你好,看了你写的教程收益匪浅,现在我遇见这样的问题,情况是这样的:
In Analysis 'Flow Analysis 1': The ANSYS solution units defined in the input file via the /UNITS,MPA command differ from the current CFX solution units. All
necessary unit conversions will be applied to data transfers between the solvers.
应该是单位的问题吧,但是我的单位都是一样的呀,实在不知道该怎么办了,关键是解算的时候就报错了
This run of the CFX-12.1 Solver started at 11:49:59 on 19 Jul 2010 by
user Administrator on DW (intel_xeon64.sse2_winnt) using the command:
  "E:\Program Files\ANSYS Inc\v121\CFX\bin\perllib\cfx5solve.pl"
    -stdout-comms -batch -ccl -
Setting up CFX Solver run ...
|            Processing ANSYS Input File (Running CCL2MF)            |
Created G:\project-dw\DW2010\CFD\practice\Unnamed_004.ansys\ANSYS.mf
|                       Starting ANSYS Solver                        |
|                    CFX Command Language for Run                    |
LIBRARY:
   MATERIAL: Material 1
     Material Group = User
     Option = Pure Substance
     PROPERTIES:
       Option = General Material
       EQUATION OF STATE:
         Density = 1 [kg m^-3]
         Molar Mass = 1.0 [kg kmol^-1]
         Option = Value
       END
       DYNAMIC VISCOSITY:
         Dynamic Viscosity = 0.2 [Pa s]
         Option = Value
       END
     END
   END
END
FLOW: Flow Analysis 1
   SOLUTION UNITS:
     Angle Units = [rad]
     Length Units = [m]
     Mass Units = [kg]
     Solid Angle Units = [sr]
     Temperature Units = [K]
     Time Units =
   END
   ANALYSIS TYPE:
     Option = Transient
     EXTERNAL SOLVER COUPLING:
       ANSYS Input File = G:\project-dw\DW2010\CFD\lgwh\lgoh.inp
       Option = ANSYS MultiField
       COUPLING TIME CONTROL:
         COUPLING INITIAL TIME:
           Option = Automatic
         END
         COUPLING TIME DURATION:
           Option = Total Time
           Total Time = 1
         END
         COUPLING TIME STEPS:
           Option = Timesteps
           Timesteps = 0.01
         END
       END
     END
     INITIAL TIME:
       Option = Coupling Initial Time
     END
     TIME DURATION:
       Option = Coupling Time Duration
     END
     TIME STEPS:
       Option = Coupling Timesteps
     END
   END
   DOMAIN: Default Domain
     Coord Frame = Coord 0
     Domain Type = Fluid
     Location = part_2
     BOUNDARY: inlet
       Boundary Type = INLET
       Location = inlet
       BOUNDARY CONDITIONS:
         FLOW REGIME:
           Option = Subsonic
         END
         MASS AND MOMENTUM:
           Normal Speed = 80 [m s^-1]
           Option = Normal Speed
         END
         MESH MOTION:
           Option = Stationary
         END
       END
     END
     BOUNDARY: interface
       Boundary Type = WALL
       Location = interface
         MASS AND MOMENTUM:
           Option = No Slip Wall
         END
         MESH MOTION:
           ANSYS Interface = FSIN_1
           Receive from ANSYS = Total Mesh Displacement
           Send to ANSYS = Total Force
         END
       END
     END
     BOUNDARY: outlet
       Boundary Type = OUTLET
       Location = outlet
         FLOW REGIME:
           Option = Subsonic
         END
         MASS AND MOMENTUM:
           Option = Static Pressure
           Relative Pressure = 0 [Pa]
         END
         MESH MOTION:
           Option = Stationary
         END
       END
     END
     BOUNDARY: sym1
       Boundary Type = SYMMETRY
       Location = sym1
         MESH MOTION:
           Option = Unspecified
         END
       END
     END
     BOUNDARY: sym2
       Location = sym2
         MESH MOTION:
         END
       END
     END
     BOUNDARY: wall
       Location = wall
         MASS AND MOMENTUM:
         END
         MESH MOTION:
           Option = Stationary
         END
       END
     END
     DOMAIN MODELS:
       BUOYANCY MODEL:
         Option = Non Buoyant
       END
       DOMAIN MOTION:
         Option = Stationary
       END
       MESH DEFORMATION:
         Option = Regions of Motion Specified
         MESH MOTION MODEL:
           Option = Displacement Diffusion
           MESH STIFFNESS:
             Option = Increase near Small Volumes
             Stiffness Model Exponent = 10
           END
         END
       END
       REFERENCE PRESSURE:
         Reference Pressure = 1 [atm]
       END
     END
     FLUID DEFINITION: Fluid 1
       Material = Material 1
       Option = Material Library
       MORPHOLOGY:
         Option = Continuous Fluid
       END
     END
     FLUID MODELS:
       COMBUSTION MODEL:
         Option = None
       END
       HEAT TRANSFER MODEL:
         Option = None
       END
       THERMAL RADIATION MODEL:
         Option = None
       END
       TURBULENCE MODEL:
         Option = Laminar
       END
     END
   END
   INITIALISATION:
     Option = Automatic
     INITIAL CONDITIONS:
       Velocity Type = Cartesian
       CARTESIAN VELOCITY COMPONENTS:
         Option = Automatic with Value
         U = 0 [m s^-1]
         V = 0 [m s^-1]
         W = 0 [m s^-1]
       END
       STATIC PRESSURE:
       END
     END
   END
   OUTPUT CONTROL:
     MONITOR OBJECTS:
       MONITOR BALANCES:
         Option = Full
       END
       MONITOR FORCES:
         Option = Full
       END
       MONITOR PARTICLES:
         Option = Full
       END
       MONITOR POINT: Monitor Point 1
         Cartesian Coordinates = 0.0[m],0.0[m],0.0[m]
         Option = Cartesian Coordinates
         Output Variables List = Pressure,Total Mesh Displacement,Velocity
       END
       MONITOR RESIDUALS:
         Option = Full
       END
       MONITOR TOTALS:
         Option = Full
       END
     END
     RESULTS:
       File Compression Level = Default
       Option = Standard
     END
     TRANSIENT RESULTS: Transient Results 1
       Include Mesh = No
       Option = Selected Variables
       OUTPUT FREQUENCY:
         Option = Every Coupling Step
       END
     END
   END
   SOLVER CONTROL:
     ADVECTION SCHEME:
       Option = High Resolution
     END
     CONVERGENCE CONTROL:
       Maximum Number of Coefficient Loops = 3
       Minimum Number of Coefficient Loops = 1
       Timescale Control = Coefficient Loops
     END
     CONVERGENCE CRITERIA:
       Residual Target = 1.E-4
       Residual Type = RMS
     END
     EXTERNAL SOLVER COUPLING CONTROL:
       COUPLING DATA TRANSFER CONTROL:
         Convergence Target = 1e-2
         Under Relaxation Factor = 0.75
       END
       COUPLING STEP CONTROL:
         Maximum Number of Coupling Iterations = 10
         Minimum Number of Coupling Iterations = 1
         SOLUTION SEQUENCE CONTROL:
           Solve ANSYS Fields = After CFX Fields
         END
       END
     END
     TRANSIENT SCHEME:
       Option = Second Order Backward Euler
       TIMESTEP INITIALISATION:
         Option = Automatic
       END
     END
   END
END
COMMAND FILE:
   Version = 12.1
   Results Version = 12.1
END
SIMULATION CONTROL:
   EXECUTION CONTROL:
     EXECUTABLE SELECTION:
       Double Precision = Off
     END
     INTERPOLATOR STEP CONTROL:
       Runtime Priority = Standard
       MEMORY CONTROL:
         Memory Allocation Factor = 1.0
       END
     END
     MFX RUN CONTROL:
       MFX RUN DEFINITION:
         MFX Run Mode = Start ANSYS and CFX
         Process ANSYS Input File = On
         Restart ANSYS Run = Off
       END
       MFX SOLVER CONTROL:
         ANSYS Installation Root = E:\Program Files\ANSYS Inc\v121\ansys
         ANSYS License = ANSYS
       END
     END
     PARALLEL HOST LIBRARY:
       HOST DEFINITION: dw
         Host Architecture String = winnt
         Installation Root = E:\Program Files\ANSYS Inc\v%v\CFX
       END
     END
     PARTITIONER STEP CONTROL:
       Multidomain Option = Independent Partitioning
         Use Large Problem Partitioner = Off
       END
       MEMORY CONTROL:
       END
       PARTITIONING TYPE:
         MeTiS Type = k-way
         Option = MeTiS
         Partition Size Rule = Automatic
       END
     END
     RUN DEFINITION:
       Run Mode = Full
       Solver Input File = G:\project-dw\DW2010\CFD\lgwh\Unnamed.def
     END
     SOLVER STEP CONTROL:
       MEMORY CONTROL:
       END
       PARALLEL ENVIRONMENT:
         Number of Processes = 1
         Start Method = Serial
       END
       PROCESS COUPLING:
         Process Name = CFX
         Host Port = 2985
         Host Name = DW
       END
     END
   END
END
|                               Solver                               |
|                        ANSYS CFX Solver 12.1                       |
| Version 2009.10.15-23.08            Fri Oct 16 00:14:12 GMTDT 2009 |
|                        Executable Attributes                       |
| single-int32-32bit-novc8-noifort-novc6-optimised-supfort-noprof-nos|
| Copyright 2009 ANSYS Inc.                                          |
|                          Job Information                           |
Run mode:       serial run
Host computer:  DW
Job started:    Mon Jul 19 11:50:23 2010
Connecting to the following master process:
     Host Name   : DW
     Port Number :   2985
|        Memory Allocated for Run  (Actual usage may be less)        |
  Data Type      Kwords  Words/Node  Words/Elem      Kbytes Bytes/Node
  Real          20691.5      684.60      818.82     80826.2    2738.42
  Integer        3209.0      106.17      126.99     12535.2     424.70
  Character      3442.0      113.88      136.21      3361.3     113.88
  Logical          65.0        2.15        2.57       253.9       8.60
  Double          311.2       10.30       12.32      2431.6      82.38
|                          Mesh Statistics                           |
| Domain Name          | Orthog. Angle | Exp. Factor  | Aspect Ratio |
|                      | Minimum [deg] |   Maximum    |    Maximum   |
| Default Domain       |       85.9 OK |         1 OK |         1 OK |
|                      |  %!  %ok  %OK | %!  %ok  %OK | %!  %ok  %OK |
| Default Domain       |   0    0  100 |  0    0  100 |  0    0  100 |
Domain Name : Default Domain
     Total Number of Nodes                                =       30224
     Total Number of Elements                             =       25270
         Total Number of Hexahedrons                      =       25270
     Total Number of Faces                                =        9558
|                  User Defined Monitor Information                  |
|                       ****** Notice ******                         |
| Monitor points are assigned to the nearest vertex and will         |
| change position in case of moving mesh or rotating domains.        |
Monitor Point: Monitor Point 1
   Domain: Default Domain
   User specified location (x,y,z) :  0.000E+00,  0.000E+00,  0.000E+00
   Assigned vertex location (x,y,z):  2.857E-03,  1.846E-03, -5.055E-04
   Distance to specified location  :  3.439E-03
   Valid variables from output variable list:
                        Pressure
                        Velocity
|      Initial Conditions Supplied by Fields in the Input Files      |
     Mesh Coordinates
|                     Average Scale Information                      |
     Global Length                                         = 1.6755E-01
     Minimum Extent                                        = 4.0000E-02
     Maximum Extent                                        = 5.2000E-01
     Density                                               = 1.0000E+00
     Dynamic Viscosity                                     = 2.0000E-01
     Velocity                                              = 0.0000E+00
|    Boundary Condition Data Supplied by External Solver Coupling    |
ANSYS Multi-field Solver : ANSYS
     CFX Boundary    : interface
     CFX Variable    : Total Mesh Displacement
     ANSYS Interface : 1
     ANSYS Variable  : DISP
|                Checking for Isolated Fluid Regions                 |
No isolated fluid regions were found.
|              The Equations Solved in This Calculation              |
Subsystem : Mesh Displacement
   X-Disp
   Y-Disp
   Z-Disp
Subsystem : Momentum and Mass
   U-Mom
   V-Mom
   W-Mom
   P-Mass
CFD Solver started: Mon Jul 19 11:50:36 2010
|                       Convergence History                          |
| Writing transient file 0_CS.trn                                    |
|   Name   : Transient Results 1                                     |
|   Type   : Selected Variables                                      |
|   Option : Every Coupling Step                                     |
|                      Timestepping Information                      |
|       Timestep       |  RMS Courant Number  |  Max Courant Number  |
|      1.0000E-02      |          0.00        |          0.00        |
TIME STEP =     1 SIMULATION TIME = 1.0000E-02 CPU SECONDS = 1.641E+00
|                 COUPLING/STAGGER ITERATION =    1                  |
| SOLVING : Mesh Displacement                                        |
|       Equation       | Rate | RMS Res | Max Res |  Linear Solution |
| X-Disp               | 0.00 | 0.0E+00 | 0.0E+00 |       0.0E+00  OK|
| Y-Disp               | 0.00 | 0.0E+00 | 0.0E+00 |       0.0E+00  OK|
| Z-Disp               | 0.00 | 0.0E+00 | 0.0E+00 |  6.2  0.0E+00  OK|
|                          Mesh Statistics                           |
COEFFICIENT LOOP ITERATION =    1              CPU SECONDS = 2.984E+00
| U-Mom                | 0.00 | 0.0E+00 | 0.0E+00 |       0.0E+00  OK|
| V-Mom                | 0.00 | 6.3E-03 | 6.6E-02 |       1.2E-01  ok|
| W-Mom                | 0.00 | 0.0E+00 | 0.0E+00 |       0.0E+00  OK|
| P-Mass               | 0.00 | 1.2E-03 | 1.2E-02 | 12.2  5.0E-02  OK|
COEFFICIENT LOOP ITERATION =    2              CPU SECONDS = 5.297E+00
| U-Mom                | 0.00 | 1.5E-04 | 2.7E-03 |       2.2E-01  ok|
| V-Mom                | 0.89 | 5.6E-03 | 1.2E-01 |       1.6E-02  OK|
| W-Mom                | 0.00 | 4.5E-03 | 1.1E-01 |       1.2E-02  OK|
| P-Mass               | 0.63 | 7.7E-04 | 2.2E-02 | 19.7  7.3E-02  OK|
|  A wall has been placed at portion(s) of an OUTLET                 |
|  boundary condition (at  20.4% of the faces,  20.4% of the area)   |
|  to prevent fluid from flowing into the domain.                    |
|  The boundary condition name is: outlet.                           |
|  The fluid name is: Fluid 1.                                       |
|  If this situation persists, consider switching                    |
|  to an Opening type boundary condition instead.                    |
COEFFICIENT LOOP ITERATION =    3              CPU SECONDS = 7.516E+00
| U-Mom                | 0.20 | 2.9E-05 | 1.9E-03 |       7.3E-01  ok|
| V-Mom                | 0.97 | 5.5E-03 | 1.6E-01 |       4.3E-02  OK|
| W-Mom                | 0.92 | 4.2E-03 | 9.9E-02 |       2.2E-02  OK|
| P-Mass               | 2.49 | 1.9E-03 | 9.6E-02 | 12.2  5.8E-02  OK|
|  boundary condition (at  37.5% of the faces,  37.5% of the area)   |
| ERROR #002100061 has occurred in subroutine SERVE_CLIENTS.         |
| Message:                                                           |
| The connection between this CFX process and an external process    |
| has died unexpectedly.  The following error was received:          |
|   External process  : ANSYS                                        |
|   Error experienced : Read                                         |
| ** This error is fatal:  Terminating ANSYS CFX Solver execution ** |
| Please review the output, error and log files from both the CFX    |
| and external processes to determine the cause of the error.        |
|                An error has occurred in cfx5solve:                 |
| The ANSYS CFX solver exited with return code 1.   No results file  |
| has been created.                                                  |
End of solution stage.
| The following transient and backup files written by the ANSYS CFX  |
| solver have been saved in the directory                            |
| G:\project-dw\DW2010\CFD\practice\Unnamed_004:                     |
| 0_CS.trn                                                           |
| ANSYS Solver terminated with return code 1024                      |
| The results from this run of the ANSYS solver have been written to |
| G:\project-dw\DW2010\CFD\practice\Unnamed_004.ansys                |
| The following user files have been saved in the directory          |
| mon        |
发表于 2010-7-24 14:46:36 | 显示全部楼层 来自 陕西西安
下来看了,谢谢
发表于 2010-8-7 22:52:38 | 显示全部楼层 来自 西安交通大学
这个例题是最经典的,adina还有很多CFD软件都有,感谢楼主
发表于 2010-8-8 11:13:48 | 显示全部楼层 来自 江苏徐州
下载下来看看,谢谢
发表于 2010-8-8 22:18:36 | 显示全部楼层 来自 北京房山
我也是0啊,多谢
发表于 2010-8-9 18:00:42 | 显示全部楼层 来自 山东东营
楼主有catia建的三维实体,我想问问能不能用proe或SolidWorks建保存为不同body呢?
发表于 2010-8-9 18:15:47 | 显示全部楼层 来自 江苏无锡
谢谢亲爱的楼主的慷慨分享!!谢谢!!
发表于 2010-8-9 18:30:09 | 显示全部楼层 来自 山东东营
发表于 2010-8-10 11:52:04 | 显示全部楼层 来自 河南洛阳
好好学习学习,谢谢啊
发表于 2010-8-14 11:39:34 | 显示全部楼层 来自 浙江温州
要的就是基础呵呵 我新手
发表于 2010-8-15 22:34:38 | 显示全部楼层 来自 台湾
謝謝大大的分享.正在學習中.
发表于 2010-8-18 22:08:05 | 显示全部楼层 来自 上海
正需要这方面的文章,谢谢!
发表于 2010-8-19 12:48:11 | 显示全部楼层 来自 江苏镇江
不简单啊,不过是好东西的
GMT+8, 2026-1-9 18:26 , Processed in 0.040519 second(s), 8 queries , Gzip On, MemCache On.
