查看: 5255|回复: 64
[其他] 焊接静力分析
发表于 2010-7-4 19:52:50 | 显示全部楼层 |阅读模式 来自 挪威
不是很准确。抛砖引玉吧。献丑了
我刚做了一个分析fillet weld,并和MATHCAD的结果比较了一下。由于文档在办公室无法上传。注意不是焊接过程分析,只是静力分析。
这里大概定义spot weld分析。
在DM中定义spot weld。然后按照contact分析。
 楼主| 发表于 2010-7-4 19:54:54 | 显示全部楼层 来自 挪威
Spot welds are used to connect individual surface body parts together to form surface body model assemblies, just as contact is used for solid body part assemblies. Structural loads are transferred from one surface body part to another via the spot weld connection points, allowing for simulation of surface body model assemblies.
Spot Weld Details
Spot welds are usually defined in the CAD system and automatically generated upon import, although you can define them manually in Simulation after the model is imported. Spot welds then become hard points in the geometric model. Hard points are vertices in the geometry that are linked together using beam elements during the meshing process.
Spot weld objects are located in the Connections object in the Tree Outline. When selected in the tree, they appear in the graphical window highlighted by a black square around a white dot on the underlying vertices, with an annotation.
If a surface body model contains spot weld features in the CAD system, then spot welds are auto-generated when the model is read into Simulation or when Generate Contact on Update is set to Yes in the Details view of the Connections object in the Tree Outline. This is similar to the way in which Simulation automatically constructs contact condition when reading in assemblies of solid models.
You can manually generate spot welds as you would insert any new object into the Outline tree. Either insert a spot weld object from the context menu and then pick two appropriate vertices in the model, or pick two appropriate vertices and then insert the spot weld object.
You can define spot welds for CAD models that do not have a spot weld feature in the CAD system, as long as the model contains vertices at the desired locations. You must define spot welds manually in these cases.
Spot Weld Assumptions and Restrictions
Spot welds do not act to prevent penetration of the connected surface body in areas other than at the spot weld location. Penetration of the joined surface body is possible in areas where spot welds do not exist.
Spot welds only transfer structural loads and structural effects between surface body parts. Therefore they are appropriate for displacement, stress, elastic strain, and frequency solutions.
DesignModeler generates spot welds. The only CAD system whose spot welds can be fully realized in ANSYS Workbench at this time is Unigraphics. The APIs of the remaining CAD systems either do not handle spot welds, or the ANSYS Workbench software does not read spot welds from these other CAD systems.
 楼主| 发表于 2010-7-4 20:04:23 | 显示全部楼层 来自 挪威
fillet weld的分析-公式
发表于 2010-7-4 20:25:10 | 显示全部楼层 来自 北京
建议用hm做前处理,可以直接加载焊接单元,更贴合你的分析公式
精度也不错哦
 楼主| 发表于 2010-7-4 20:33:11 | 显示全部楼层 来自 挪威
我不会HM。有时间学习一下
 楼主| 发表于 2010-7-4 21:15:16 | 显示全部楼层 来自 挪威
一些焊接资料,希望有用
发表于 2010-7-4 23:50:09 | 显示全部楼层 来自 陕西咸阳
楼主是主要研究焊接静力分析?
请问你搞过焊接固有应变分析没有?谢谢!
 楼主| 发表于 2010-7-5 01:36:55 | 显示全部楼层 来自 挪威
我不是高焊接分析的,只是有时候工程需要焊缝的静力分析。焊接固有应变分析,我没概念,这段时间在想laser beam焊接的模拟。以前有个项目,没拿到,始终是心病。
 楼主| 发表于 2010-7-5 01:46:12 | 显示全部楼层 来自 挪威
对不起,已经有人发布过了
http://forum.simwe.com/viewthrea ... ghlight=Spot%2BWeld
另外贴一篇NASTRAN里的SPOT WELD的分析,可以借鉴
 楼主| 发表于 2010-7-5 17:03:01 | 显示全部楼层 来自 法国
一些计算结果。基本吻合。只是为了验证一下是否满足工程需要。
发表于 2010-7-5 17:32:42 | 显示全部楼层 来自 江苏扬州
优秀文章,感谢分享~~
发表于 2010-7-5 21:53:07 | 显示全部楼层 来自 江西新余
谢谢,学习了
发表于 2010-7-6 06:04:10 | 显示全部楼层 来自 广东珠海
优秀的文章啊!让我思维开拓了!~
谢谢楼主的好文章!
焊接件的应力分析,也是一个难点!
发表于 2010-7-6 09:46:41 | 显示全部楼层 来自 广东深圳
灰常感谢昏享!
发表于 2010-7-6 11:05:55 | 显示全部楼层 来自 浙江杭州
请问版主,你做的点焊分析是贴合接触吗?我做贴合点焊时,好像ds中没有识别点焊接触,删除绑定约束时,系统求解出错,我猜是缺少接触。该如何解决呢
1# sunnygu
 楼主| 发表于 2010-7-6 14:23:24 | 显示全部楼层 来自 法国
上面的是点焊,下面的是FILLET WELD.cooheting你说的问题,我注意到了。你可以参考一下ANSYS网站的例子。
http://forum.simwe.com/thread-939946-1-1.html
我发EMAIL问问他们。希望能得到正解。
 楼主| 发表于 2010-7-6 14:42:18 | 显示全部楼层 来自 法国
个人认为对FILLET讲解的比较详细的资料
发表于 2010-7-6 15:20:06 | 显示全部楼层 来自 浙江杭州
感谢sunnygu版
17# sunnygu
 楼主| 发表于 2010-7-7 14:45:51 | 显示全部楼层 来自 美国
收到技术支持的文档,的确需要建立接触。
 楼主| 发表于 2010-7-7 15:03:05 | 显示全部楼层 来自 美国
建议用BEAM 链接。可以输出很多数据
GMT+8, 2026-1-2 19:59 , Processed in 0.041705 second(s), 18 queries , Gzip On, MemCache On.
