- 2008-4-1
楼主 |
发表于 2010-8-10 22:08:53
来自 日本
6.2.3 Eigenvalue buckling prediction
Order of calculation and formation of the stiffness matrices
In an eigenvalue buckling prediction step Abaqus/Standard first does a static perturbation analysis to determine the incremental stresses, , due to . If the base state did not include geometric nonlinearity, the stiffness matrix used in this static perturbation analysis is the tangent elastic stiffness. If the base state did include geometric nonlinearity, initial stress and load stiffness terms (due to the preload, ) are included. The stiffness matrix corresponding to and is then formed.
In the eigenvalue extraction portion of the buckling step, the stiffness matrix corresponding to the base state geometry is formed. Initial stress and the load stiffness terms due to the preload, , are always included regardless of whether or not geometric nonlinearity is included and are calculated based on the geometry of the base state. |
