- 2010-7-19
警告是这样:
A distributed coupling definition with coupling=structural will ignore the structural coupling as at least some of the nodes in the cloud do not have all three rotational degrees of freedom active
For *tie pair (assembly__pickedsurf144-assembly__pickedsurf143), adjusted nodes with very small adjustments were not printed. Specify *preprint,model=yes for complete printout.
For *tie pair (assembly__pickedsurf146-assembly__pickedsurf145), adjusted nodes with very small adjustments were not printed. Specify *preprint,model=yes for complete printout.
For *tie pair (assembly__pickedsurf148-assembly__pickedsurf147), adjusted nodes with very small adjustments were not printed. Specify *preprint,model=yes for complete printout.
For *tie pair (assembly__pickedsurf150-assembly__pickedsurf149), adjusted nodes with very small adjustments were not printed. Specify *preprint,model=yes for complete printout.
错误是这样:
Time increment required is less than the minimum specified
Abaqus/Standard Analysis exited with an error - Please see the message file for possible error messages if the file exists. |
