- 2008-11-13
我做的是制动盘和摩擦片的温度场分析,我做的是让制动盘移动,每次让制动盘移动一个距离,然后加载热流密度和对流进行计算,但发现循环的时候,第3步以后的结果却都是一样的,也就是说相当于加载热流密度和对流没有起到作用,我调试了一个多星期,各个方面都考虑了,我的命令流应该说是没有问题的,但实在找不除原因,希望高手帮忙解决。QQ:1157806538(可以加QQ聊)
TEL:13109806861
FINI
/CLEAR
/FILN,Brake_thermal_1
/TITLE,THERMAL ANALYSIS OF DISC BRAKE
WPSTYLE,,,,,,,,1
/TRIAD,OFF
/PREP7
CYL4,,,70E-3,,440E-3,,17.5E-3 !摩擦盘
BLOCK,200E-3,400E-3,-150E-3,150E-3,0,-13E-3
asel,,loc,z,-13E-3
VEXT,all,,,,,-20E-3
ALLSEL
VPLOT
VGLUE,2,3
ET,1,70
ET,2,151
!Q345D制动盘材料特性
MP,PRXY,1,0.31 !泊松比
MP,DENS,1,7870 !制动盘密度
MP,MU,1,0.38 !摩擦系数
MPTEMP
MPTEMP,1,260,373,473,573,673,1773
MPDATA,EX,1,,2.12e11,2.08e11,2.03e11,1.97e11,1.85e11,1.82e11 !弹性模量
MPDATA,KXX,1,,43.6,42.3,40.9,39.4,37.8,36.1 !热导率
MPDATA,C,1,,410 , 460,507,548,582,605 !比热容
MPDATA,ALPX,1,,12.2E-6, 12.8E-6, 13.4E-6, 13.9E-6, 14.5E-6, 14.7E-6 !线膨胀系数
!烧结金属材料特性
MP,PRXY,2,0.32 !泊松比
MP,DENS,2,8410 !制动盘密度
MP,MU,2,0.38 !摩擦系数
MP,C, 2,384 !比热容
MPTEMP
MPDATA,EX,2,,0.853e11,0.834e11,0.795e11,0.726e11,0.697e11,0.668e11 !弹性模量
MPDATA,KXX,2,,0.39e3, 0.38e3,0.368e3,0.352e3,0.344e3,0.339e3 !热导率
MPDATA,ALPX,2,,17.7E-6, 17.8E-6, 18.0E-6, 18.5E-6, 19.2E-6, 19.9E-6 !线膨胀系数
!ZG340-640制动衬片基体材料特性
MP,PRXY,3,0.3 !泊松比
MP,DENS,3,7820 !制动盘密度
MP,ALPX,3,11.3E-6 !线膨胀系数
MPTEMP
MPDATA,EX,3,,1.95e11,1.92e11,1.87e11,1.85e11,1.82e11,1.80e11 !弹性模量
MPDATA,KXX,3,,0.036e3,0.038e3,0.0424e3,0.0413e3,0.0396e3,0.0377e3 !热导率
MPDATA,C,3,,470,486,494,511,517,557 !比热容
VSEL,S,,,1
VATT,1,1,1
VSEL,S,,,2
VATT,2,1,1
VSEL,S,,,3
VATT,3,1,1
ALLSEL
ESIZE,20e-3
WPROTA,,90,
VSBW,1
WPROTA,,,-90
VSBW,ALL
MSHAPE,0,3D
MSHKEY,1
VMESH,ALL
WPROTA,,,90
WPROTA,,-90,
ALLSEL
!NUMMRG,ALL
!NUMCMP,ALL
!DEFINE FULX NODE
VSEL,S,LOC,Z,-13E-3,0
ASLV
ASEL,R,LOC,Z,0
CM,PADFLU,AREA !定义摩擦片热流面
NSLA
CM,NPADFLU,NODE !定义热流节点
VSEL,S,LOC,Z,0,17.5E-3
VPLOT
NSLV,S,1
NPLOT
NSEL,R,LOC,X,200E-3,400E-3
NSEL,R,LOC,Y,-150E-3,150E-3
NSEL,R,LOC,Z,0
CM,DISFLU,NODE !定义制动盘热流节点
ALLSEL
ASLV,s,1
CSYS,1
ASEL,S,LOC,X,70E-3
ASEL,A,LOC,X,440E-3
CSYS,4
ASEL,A,LOC,Z,17.5E-3
!ASEL,A,,,1
!ASEL,A,,,27
!ASEL,A,,,32
!ASEL,A,,,36
CM,ADIS,AREA !定义圆盘对流面
ALLSEL
NSEL,S,LOC,Z,0
CMSEL,U,DISFLU
CMSEL,U,NPADFLU
CM,NCONT,NODE !定义接触面对流点组件
ALLSEL
VSEL,S,LOC,Z,0,-33E-3
ASLV
ASEL,R,LOC,Y,-150E-3,150E-3
ASEL,U,LOC,Z,0
CM,APAD,AREA !定义衬片及烧结金属圆柱体
FINISH
/SOL
csys,4
ANTYPE,TRANS
!NLGEOM,1
LUMPM,0 !关闭集中质量矩阵计算格式
NROPT,FULL
!TIMINT,0,STRUCT !关闭结构时间积分选项
!TOFFST,460
!TINTP,,,,1 !定义瞬态积分参数
DELTIM,0.001,0.001,0.003
AUTOTS,1
LNSRCH,1
PRED,ON
KBC,0
TIME,0.01
!SSTIF,0 !关闭应力刚化影响
OUTRES,ERASE
OUTRES,ALL,ALL
EQSLV, , ,
PRECISION,0 !定义双精度求解
!MSAVE,0
!IC,ALL,TEMP,298 !定义初始温度
!SFA, ACYL,,CONV,5.3,298
TUNIF,298
SFA, APAD,,CONV,5.3,298
SFA, ADIS,,CONV,5.3,298
SF,NCONT,CONV,5.3,298
csys,4
!CSWPLA,11,0
!CSYS,11
allsel
CPINTF,TEMP,1E-8
*SET,FW,0.2505
!定义制动盘的热流密度函数
*DEL,_FNCNAME
*DEL,_FNCMTID
*DEL,_FNCCSYS
*SET,_FNCNAME,'tdisflu'
*SET,_FNCCSYS,0
! /INPUT,disflu.func,,,1
*DIM,%_FNCNAME%,TABLE,6,16,1,,,,%_FNCCSYS%
! Begin of equation: 0.2505*623800*(219.8-49.15*{TIME})*sqrt({X}^2+{Y}^2)
*SET,%_FNCNAME%(0,0,1), 0.0, -999
*SET,%_FNCNAME%(2,0,1), 0.0
*SET,%_FNCNAME%(3,0,1), 0.0
*SET,%_FNCNAME%(4,0,1), 0.0
*SET,%_FNCNAME%(5,0,1), 0.0
*SET,%_FNCNAME%(6,0,1), 0.0
*SET,%_FNCNAME%(0,1,1), 1.0, -1, 0, 0.2505, 0, 0, 0
*SET,%_FNCNAME%(0,2,1), 0.0, -2, 0, 623800, 0, 0, -1
*SET,%_FNCNAME%(0,3,1), 0, -3, 0, 1, -1, 3, -2
*SET,%_FNCNAME%(0,4,1), 0.0, -1, 0, 49.15, 0, 0, 1
*SET,%_FNCNAME%(0,5,1), 0.0, -2, 0, 1, -1, 3, 1
*SET,%_FNCNAME%(0,6,1), 0.0, -1, 0, 219.8, 0, 0, -2
*SET,%_FNCNAME%(0,7,1), 0.0, -4, 0, 1, -1, 2, -2
*SET,%_FNCNAME%(0,8,1), 0.0, -1, 0, 1, -3, 3, -4
*SET,%_FNCNAME%(0,9,1), 0.0, -2, 0, 2, 0, 0, 2
*SET,%_FNCNAME%(0,10,1), 0.0, -3, 0, 1, 2, 17, -2
*SET,%_FNCNAME%(0,11,1), 0.0, -2, 0, 2, 0, 0, 3
*SET,%_FNCNAME%(0,12,1), 0.0, -4, 0, 1, 3, 17, -2
*SET,%_FNCNAME%(0,13,1), 0.0, -2, 0, 1, -3, 1, -4
*SET,%_FNCNAME%(0,14,1), 0.0, -2, 16, 1, -2, 0, 0
*SET,%_FNCNAME%(0,15,1), 0.0, -3, 0, 1, -1, 3, -2
*SET,%_FNCNAME%(0,16,1), 0.0, 99, 0, 1, -3, 0, 0
! End of equation: 0.2505*623800*(219.8-49.15*{TIME})*sqrt({X}^2+{Y}^2)
!定义摩擦片的热流密度函数
*DEL,_FNCNAME
*DEL,_FNCMTID
*DEL,_FNCCSYS
*SET,_FNCNAME,'tpadflu'
*SET,_FNCCSYS,0
! /INPUT,padflu.func,,,1
! Begin of equation: 0.7495*623800*(219.8-49.15*{TIME})*sqrt({X}^2+{Y}^2)
*SET,%_FNCNAME%(0,1,1), 1.0, -1, 0, 0.7495, 0, 0, 0
! End of equation: 0.7495*623800*(219.8-49.15*{TIME})*sqrt({X}^2+{Y}^2)
SF,DISFLU,HFLUX,%tdisflu%
SFA,PADFLU,,HFLUX,%tpadflu%
ALLSEL
SOLVE
FINISH
FINISH
*do,I,2,10
!I=2
/FILNAME,Brake_thermal_%I%,1
/SOLU
ALLSEL
SFDELE,DISFLU,HFLUX
SFDELE,NCONT,CONV
/REPLO
FINISH
/PREP7
vsel,s,loc,z,0,17.5e-3
vplot
csys,1
alph1=2.198*(I-1)-0.5*49.15*1E-4*(I-1)**2
alph2=2.198*(I-2)-0.5*49.15*1E-4*(I-2)**2
PI=4*ATAN(1)
dis=(alph1-alph2)*180/PI
vgen,,all,,,,dis,,,,1
vplot
allsel
vplot
csys,4
CMDELE,DISFLU
CMDELE,NCONT
VPLOT
NSLV,S,1
NPLOT
NSEL,R,LOC,Z,0
ALLSEL
NSEL,S,LOC,Z,0
CMSEL,U,DISFLU
CMSEL,U,NPADFLU
FINISH
/SOL
!ALLSEL
!ANTYPE,,REST,1,5,1
LDREAD,TEMP,,,0.01,1,'Brake_thermal_%I-1%','rth',' '
TIME,0.01
csys,4
allsel
CPINTF,TEMP,1E-8
!定义制动盘的热流密度函数
*DEL,tdisflu
*DEL,_FNCNAME
*DEL,_FNCMTID
*DEL,_FNCCSYS
*SET,_FNCCSYS,0
*DIM,%_FNCNAME%,TABLE,6,18,1,,,,%_FNCCSYS%
! Begin of equation: 0.2505*623800*(219.8-49.15*({TIME}+0.03))*sqrt({X}^2+{Y}^
! 2)
*SET,%_FNCNAME%(0,4,1), 0.0, -1, 0, 0.0%I%, 0, 0, 1
*SET,%_FNCNAME%(0,5,1), 0.0, -2, 0, 1, 1, 1, -1
*SET,%_FNCNAME%(0,6,1), 0.0, -1, 0, 49.15, 0, 0, -2
*SET,%_FNCNAME%(0,7,1), 0.0, -4, 0, 1, -1, 3, -2
*SET,%_FNCNAME%(0,8,1), 0.0, -1, 0, 219.8, 0, 0, -4
*SET,%_FNCNAME%(0,9,1), 0.0, -2, 0, 1, -1, 2, -4
*SET,%_FNCNAME%(0,10,1), 0.0, -1, 0, 1, -3, 3, -2
*SET,%_FNCNAME%(0,11,1), 0.0, -2, 0, 2, 0, 0, 2
*SET,%_FNCNAME%(0,12,1), 0.0, -3, 0, 1, 2, 17, -2
*SET,%_FNCNAME%(0,13,1), 0.0, -2, 0, 2, 0, 0, 3
*SET,%_FNCNAME%(0,14,1), 0.0, -4, 0, 1, 3, 17, -2
*SET,%_FNCNAME%(0,15,1), 0.0, -2, 0, 1, -3, 1, -4
*SET,%_FNCNAME%(0,16,1), 0.0, -2, 16, 1, -2, 0, 0
*SET,%_FNCNAME%(0,17,1), 0.0, -3, 0, 1, -1, 3, -2
*SET,%_FNCNAME%(0,18,1), 0.0, 99, 0, 1, -3, 0, 0
! End of equation: 0.2505*623800*(219.8-49.15*({TIME}+0.03))*sqrt({X}^2+{Y}^2)
!定义摩擦片的热流密度函数
*DEL,tpadflu
*DEL,_FNCNAME
*DEL,_FNCMTID
*DEL,_FNCCSYS
*SET,_FNCCSYS,0
! Begin of equation: 0.7495*623800*(219.8-49.15*({TIME}+0.01))*sqrt({X}^2+
! {Y}^2)
! End of equation: 0.7495*623800*(219.8-49.15*({TIME}+0.01))*sqrt({X}^2+{Y}^2)
ALLSEL
SOLVE
finish
*enddo |
