- 2010-5-21
发表于 2010-10-9 15:23:03
来自 吉林长春
By default, no restart information is written for an Abaqus/Standard analysis and restart information is written only at the beginning and end of each step for an Abaqus/Explicit analysis. However, default restart requests are created automatically for every step in an analysis. The Edit Restart Requests dialog box, invoked by selecting OutputRestart Requests from the main menu bar in the Step module, allows you to specify how often you want the restart information to be written.
You can specify the frequency at which Abaqus writes data to the restart files; however, the behavior of restart differs between Abaqus/Standard and Abaqus/Explicit.
Abaqus/Standard
For an Abaqus/Standard analysis the frequency is in increments. In addition, Abaqus/Standard writes restart information at the end of the step regardless of whether the last increment corresponds to the specified frequency. By default, the frequency is set to zero, which means that Abaqus/Standard does not write any information to the restart files during the step.
Abaqus/Explicit
For an Abaqus/Explicit analysis the frequency is in time intervals. In addition, for an Abaqus/Explicit step you can choose whether the output is written at the exact time interval or at the closest approximation. However, you cannot avoid writing information to the restart files for Abaqus/Explicit steps; if you set the frequency to zero for an Abaqus/Explicit step, restart information will be written only at the end of the step. |
