以下是一个移动高斯热源的例子,命令的移动热源放电通道半径是一个确定的常量R=2.4e-5。但实际上,这个半径不是阶跃性的达到的,而是随时间扩张达到的。这个扩张时间是2us,变化权且先当作是线性的。。如果想实现这个,在命令中该怎样体现呢?
请高手具体指教!!
/UNITS,SI
/CONFIG,NRES,10000
/title,Velocity=10m/s
/PREP7
ET,1,SOLID70
MPTEMP
MPTEMP,1,20,100,200,300,400,500
MPTEMP,7,600,800,1000,1200
MPDATA,c,1,1,245,260,264,268,272,281
MPDATA,c,1,7,289,297,306, 310
MPDATA,Kxx,1,1,144.6,139,135,131,127,123
MPDATA,Kxx,1,7,116,109,103,101
mp,dens,1,10220
/VIEW,1,1,1,1
BLOCK,0,0.0010,0,0.0001,0,0.0001
SAVE
LESIZE,1,,,20
LESIZE,4,,,100
LESIZE,9,,,20
MSHKEY,1
VATT,1,1,1
VMESH,1
/PNUM,DEFA
EPLOT
FINISH
LSIZE=5e-6
V=5
TINC=LSIZE/V
pi=3.1415926
R=2.4e-5
Q=105
Qmax=Q/(pi*R*R)
MAX_TIME=101
MAX_X=101
MAX_Y=21
*DIM,laser,TABLE,MAX_X,MAX_Y,MAX_TIME,X,Y,TIME
*DO,K,1,MAX_TIME,1
*DO,I,1,MAX_X,1
laser(I,0,K)=(I-1)*LSIZE
*ENDDO
*DO,J,1,MAX_Y,1
laser(0,J,K)=(J-1)*LSIZE
*ENDDO
*DO,I,1,MAX_X,1
*DO,J,1,MAX_Y,1
XCENTER=V*(K-1)*TINC
YCENTER=5e-5
DISTANCE=SQRT(((I-1)*LSIZE-XCENTER)**2+((J-1)*LSIZE-YCENTER)**2)
*IF,DISTANCE,LE,R,THEN
laser(I,J,K)=Qmax/EXP(3*DISTANCE**2/(R**2))
*ELSE
laser(I,J,K)=0
*ENDIF
*ENDDO
*ENDDO
laser(0,0,K)=(K-1)*TINC
*ENDDO
/SOLU
ANTYPE,TRANS
TUNIF,25
KBC,1
*SET,DELT,1
TIMINT,ON
AUTOTS,OFF
TT=60e-6
*DO,TM,1E-6,TT,TINC
/VIEW,1,1,1,1
/ANG,1
/REP,FAST
FLST,2,1,5,ORDE,1
FITEM,2,2
/GO
TIME,TM
AUTOTS,0
DELTIM, , , ,1
KBC,0
TSRES,ERASE
FLST,2,1,5,ORDE,1
FITEM,2,2
/GO
SFA,P51X,1,HFLUX,%laser%
SOLVE
OUTRES,ALL,ALL,
/PSF,HFLUX,,2
/REPLOT
*ENDDO
OUTRES,ALL,ALL,
FINISH |
