- 2009-9-6
悬赏2仿真币已解决
Abaqus Product Install Verification...
Tue Nov 30 08:28:51 2010
Running system requirement checks.
Requirement: Windows Server 2003, Windows XP, Windows Vista, or Windows 7
Product: All Abaqus Products
Status: Pass - Found Microsoft Windows XP Home Edition Service Pack
3 (Build 2600) (x86).
Requirement: Microsoft Visual C++ 9.0 (2008), or 10.0 (2010)
Product: Abaqus make utility with C++
Status: Pass - Found Microsoft Visual C++ 9.0.21022.8.
Requirement: Intel Fortran Compiler 10.1 or 11.1
Product: Abaqus make utility with Fortran and Abaqus with user
subroutines
Status: Pass - Found Intel Fortran Compiler 11.1 Build 20090624
Package ID w_cprof_p_11.1.038.
Requirement: HP-MPI 01.01.00.00
Product: Abaqus analyses using MPI-based parallelization and
Abaqus/CFD
Status: Fail - Unable to locate a supported MPI implementation on
this system. For more information on the MPI-based parallel
functionality, see the section 'Parallel processing modes in
Abaqus' in the Abaqus Analysis User's Manual.
Requirement: Internet Explorer 6.0 or 7.0 or 8.0, Firefox 2.0 or 3.0 or
3.5, or greater
Product: Abaqus Documentation
Status: Pass - Found Internet Explorer 7.0.5730.13
Making d:\Temp\verify. All verification files will reside in this directory.
Abaqus/Standard
...PASS
Continuing...
Abaqus/Standard with user subroutines
...PASS
Continuing...
Abaqus/Explicit (single precision)
...PASS
Continuing...
Abaqus/Explicit (double precision)
...PASS
Continuing...
Abaqus/Explicit with user subroutines (single precision)
...PASS
Continuing...
Abaqus/Explicit with user subroutines (double precision)
...PASS
Continuing...
Abaqus/Viewer
...PASS
Continuing...
Abaqus/CAE
...PASS
Continuing...
Geometry Translator for CATIA V4
...PASS
Continuing...
Geometry Translator for CATIA V5
...PASS
Continuing...
Direct Geometry Import for CATIA V5
...PASS
Continuing...
Geometry Translator for I-DEAS
...PASS
Continuing...
Geometry Translator for Parasolid
...PASS
Continuing...
Geometry Translator for Pro/ENGINEER
...PASS
Continuing...
SolidWorks Associative Interface
...PASS
Continuing...
Abaqus/AMS
...PASS
Continuing...
Abaqus Interface for MSC.ADAMS
...PASS
Continuing...
Abaqus/Standard parametric studies
...PASS
Continuing...
Abaqus/Explicit parametric studies
...PASS
Continuing...
Abaqus/Design
...PASS
Continuing...
Abaqus Interface for Moldflow
...PASS
Continuing...
...PASS
Continuing...
...PASS
Continuing...
Abaqus make utility with object code
...PASS
Continuing...
Abaqus scripting interface
...PASS
Continuing...
Abaqus analyses using parallelization
Running thread-based parallel with 2 cpu(s)
Abaqus/Explicit domain-level parallel
...PASS
Abaqus/Standard direct solver
...PASS
Continuing...
Abaqus/Foundation
...PASS
Continuing...
Abaqus noGUI (CAE/Viewer)
...PASS
Continuing...
Abaqus/CFD
...INFORMATION
System requires were not met. Verification
procedure will be skipped
Continuing...
Clean-up...
Verification directory d:\Temp\verify has been deleted. |
最佳答案
查看完整内容
可以的。我的v6.10就是安装在32位,可以做CFD运算。
