查看: 244|回复: 3
[ADAMS CAR, Chassis, Engine] 概念悬架定转弯半径仿真出错?
发表于 2010-12-12 16:06:52 | 显示全部楼层 |阅读模式 来自 湖北武汉
悬赏10仿真币未解决
adams2005,利用MDI_Concept_Vehicle.asy(概念悬架车辆)做定转弯半径仿真,参数均为默认...
仿真设置如图,
仿真错误,msg文件为:
附件: 您需要 登录 才可以下载或查看,没有账号?注册
 楼主| 发表于 2010-12-12 16:08:17 | 显示全部楼层 来自 湖北武汉
求助,谢谢...
回复
 楼主| 发表于 2010-12-15 14:36:25 | 显示全部楼层 来自 湖北武汉
---- ERROR ----
   Attempt = 1. No convergence after 25 iterations. Best iteration = 29.
   Trying next attempt with a different set of statics parameters...
STATIC:NOCINFO
   For the last attempted iteration the equation with the largest error
   was SFORCE ac_crc.csm_front_steering.jfs_static_rotation_control.force  Error = 2.19727E+10
   The variable receiving the largest increment
   was DIFF ac_crc.testrig.sse_diff2  Delta = 5.58104E+09
STANAL:STAT_FAIL
---- ERROR ----
   Static equilibrium analysis has not been successful.
回复
 楼主| 发表于 2011-1-8 15:43:22 | 显示全部楼层 来自 湖北武汉
还是自己回答,设置静平衡求解器就可以解决....
回复
GMT+8, 2026-1-2 18:23 , Processed in 0.032199 second(s), 11 queries , Gzip On, MemCache On.
