查看: 347|回复: 6
[子程序] abaqus Verification问题求教
发表于 2010-12-18 16:26:38 | 显示全部楼层 |阅读模式 来自 安徽合肥
大家好!我装好验证子程序的时候有这个问题
Abaqus/Standard with user subroutines
            A non fatal licensing error was detected.  Please
            see d:\Temp\verify\std_user.log for details.
         ...PASS
         Continuing...
是什么原因
后面是verify文件内容 求教、
Abaqus Product Install Verification...
Sat Dec 18 16:10:03 2010
Running system requirement checks.
Requirement:    Windows Server 2003, Windows XP, Windows Vista, or Windows 7
Product:        All Abaqus Products
Status:         Pass - Found Windows 7 Ultimate  (Build 7600) (x86).
Requirement:    Microsoft Visual C++ 9.0 (2008), or 10.0 (2010)
Product:        Abaqus make utility with C++
Status:         Pass - Found Microsoft Visual C++ 9.0.21022.8.
Requirement:    Intel Fortran Compiler 10.1 or 11.1
Product:        Abaqus make utility with Fortran and Abaqus with user
                subroutines
Status:         Pass - Found Intel Fortran Compiler 11.1 Build 20100414
                Package ID w_cprof_p_11.1.065.
Requirement:    HP-MPI 01.01.00.00
Product:        Abaqus analyses using MPI-based parallelization and
                Abaqus/CFD
Status:         Pass - Found HP-MPI 01.01.00.00.
Requirement:    Internet Explorer 6.0 or 7.0 or 8.0, Firefox 2.0 or 3.0 or
                3.5, or greater
Product:        Abaqus Documentation
Status:         Pass - Found Internet Explorer 8.0.7600.16385
Making d:\Temp\verify. All verification files will reside in this directory.
Abaqus/Standard
         ...PASS
         Continuing...
         ...PASS
         Continuing...
Abaqus/Explicit (single precision)
         ...PASS
         Continuing...
Abaqus/Explicit (double precision)
         ...PASS
         Continuing...
Abaqus/Explicit with user subroutines (single precision)
            see d:\Temp\verify\xpl_user_sp.log for details.
         ...PASS
         Continuing...
Abaqus/Explicit with user subroutines (double precision)
            see d:\Temp\verify\xpl_user_dp.log for details.
         ...PASS
         Continuing...
Abaqus/Viewer
         ...PASS
         Continuing...
Abaqus/CAE
         ...PASS
         Continuing...
Geometry Translator for CATIA V4
         ...PASS
         Continuing...
Geometry Translator for CATIA V5
         ...PASS
         Continuing...
Direct Geometry Import for CATIA V5
         ...PASS
         Continuing...
Geometry Translator for I-DEAS
         ...PASS
         Continuing...
Geometry Translator for Parasolid
         ...PASS
         Continuing...
Geometry Translator for Pro/ENGINEER
         ...PASS
         Continuing...
SolidWorks Associative Interface
         ...PASS
         Continuing...
Abaqus/AMS
         ...PASS
         Continuing...
Abaqus Interface for MSC.ADAMS
         ...PASS
         Continuing...
Abaqus/Standard parametric studies
         ...PASS
         Continuing...
Abaqus/Explicit parametric studies
         ...PASS
         Continuing...
Abaqus/Design
         ...PASS
         Continuing...
Abaqus Interface for Moldflow
         ...PASS
         Continuing...
         ...PASS
         Continuing...
         ...PASS
         Continuing...
Abaqus make utility with object code
         ...PASS
         Continuing...
Abaqus scripting interface
         ...PASS
         Continuing...
Abaqus analyses using parallelization
      Running thread-based parallel with 2 cpu(s)
            Abaqus/Explicit domain-level parallel
         ...PASS
            Abaqus/Standard direct solver
         ...PASS
         Continuing...
Abaqus/Foundation
         ...PASS
         Continuing...
Abaqus noGUI (CAE/Viewer)
         ...PASS
         Continuing...
Abaqus/CFD
         ...PASS
         Continuing...
Clean-up...
Verification directory d:\Temp\verify has been deleted.
 楼主| 发表于 2010-12-19 17:34:28 | 显示全部楼层 来自 安徽合肥
别沉了 求教啊 哪位高手指点一下
发表于 2010-12-19 17:45:16 | 显示全部楼层 来自 北京工业大学
贴一下
std_user.log
发表于 2010-12-19 19:17:12 | 显示全部楼层 来自 江苏苏州
没看明白,支持下
 楼主| 发表于 2010-12-20 08:27:50 | 显示全部楼层 来自 安徽合肥
Clean-up...
d:\Temp\verify这个文件夹验证完毕后会自动删除 找不到要的log文件的
 楼主| 发表于 2010-12-20 13:29:43 | 显示全部楼层 来自 安徽合肥
文件想办法弄出来了
d:\users\abaqus60\relD\generated\inp\impl\inp_Parser.C.185:
  Parse - File: std_user.inp  Elapsed time: 0.00173589  Decryption time: 0.  C
PU time: 0.
Processing time = 0 second(s).
Abaqus JOB std_user
Abaqus 6.10-1
DriverLM executable: D:\SIMULIA\Abaqus\6.10-1\exec\eliT_DriverLM.exe
-job std_user -indir d:\Temp\verify -standard -verbose -tmpdir C:\Users\ADMINI~1\AppData\Local\Temp\Administrator_std_user_6024 -lmlog
Checkout succeeded: standard/2558DB398321
        License file: 27011@ggq
        License Server: 27011@ggq
DriverLM status: 0
Platform: win86_32
FORTRAN extension: for
Object extension: obj
Shared library name: standardU.dll
User subroutine archive file: standardU_static.lib
Utility shared library file: standardB.lib
Begin Compiling Abaqus/Standard User Subroutines
12/20/2010 1:28:47 PM
Compiling std_user.for
Compile command:  ['ifort', '/c', '/Gm', '/recursive', '/nologo', '/heap-arrays:1', '/include:d:\\Temp\\verify', 'std_user.for']
FLEXnet Licensing checkout error: The desired vendor daemon is down.
Check the lmgrd log file, or try lmreread.
Feature:       FCompW
Vendor:Host:   ggq
License path:  C:\Program Files\Common Files\Intel\Licenses\*.lic;C:\Program Files\Common Files\Intel/Licenses\*.lic;C:/Program Files/Common Files/Intel/Licenses\*.lic;C:/Program Files (x86)/Common Files/Intel/Licenses;27011@ggq;C:\PROGRA~1\Intel\Compiler\11.1\065\Bin\ia32\*.lic;
FLEXnet Licensing error:-97,121
For further information, refer to the FLEXnet Licensing documentation,
available at "www.macrovision.com".
Feature:       FComp
Vendor:Host:   ggq
Checkout succeeded: FCompW/A5742713C847
        License file: C:\Program Files\Common Files\Intel\Licenses\*.lic
        No server used
End Compiling Abaqus/Standard User Subroutines
12/20/2010 1:28:51 PM
Begin Linking Abaqus/Standard User Subroutines
export.sym: _CREEP@104
export.sym: _DFLOW@44
export.sym: _DFLUX@52
export.sym: _DISP@32
export.sym: _DLOAD@48
export.sym: _FILM@64
export.sym: _FLOW@48
export.sym: _FRIC@168
export.sym: _FRIC_COEF@76
export.sym: _GAPCON@72
export.sym: _GAPELECTR@64
export.sym: _HARDINI@48
export.sym: _HETVAL@36
export.sym: _MPC@80
export.sym: _ORIENT@48
export.sym: _RSURFU@64
export.sym: _SDVINI@32
export.sym: _SIGINI@44
export.sym: _UAMP@76
export.sym: _UANISOHYPER_INV@84
export.sym: _UANISOHYPER_STRAIN@88
export.sym: _UCORR@48
export.sym: _UCOSIMULATION@24
export.sym: _UCRACK@240
export.sym: _UEL@144
export.sym: _UELMAT@148
export.sym: _UEXPAN@48
export.sym: _UEXTERNALDB@24
export.sym: _UFIELD@44
export.sym: _UFLUID@76
export.sym: _UFLUIDLEAKOFF@96
export.sym: _UGENS@148
export.sym: _UHARD@92
export.sym: _UHYPEL@56
export.sym: _UHYPER@76
export.sym: _UINTER@200
export.sym: _UMASFL@28
export.sym: _UMAT@152
export.sym: _UMAT_SST@128
export.sym: _UMATHT@112
export.sym: _UMESHMOTION@64
export.sym: _UMOTION@24
export.sym: _UMULLINS@80
export.sym: _UPOREP@12
export.sym: _UPRESS@24
export.sym: _UPSD@24
export.sym: _URDFIL@24
export.sym: _USDFLD@108
export.sym: _UTEMP@28
export.sym: _UTRACLOAD@48
export.sym: _UTRS@44
export.sym: _UVARM@92
export.sym: _UWAVE@104
export.sym: _VOIDRI@12
Linking ['std_user.obj'] into user subroutine shared library
Link command: ['cmd', '/c', '"LINK', '/nologo', '/INCREMENTAL:NO', '/subsystem:console', '/machine:X86', '/NODEFAULTLIBIBC.LIB', '/NODEFAULTLIB:LIBCMT.LIB', '/DEFAULTLIB:OLDNAMES.LIB', '/DEFAULTLIB:LIBIFCOREMD.LIB', '/DEFAULTLIB:LIBIFPORTMD.LIB', '/DEFAULTLIB:LIBMMD.LIB', '/DEFAULTLIB:MSVCRT.LIB', '/DEFAULTLIB:kernel32.lib', '/DEFAULTLIB:user32.lib', '/DEFAULTLIB:advapi32.lib', '/FIXED:NO', '/dll', '/def:export.def', '/out:standardU.dll', 'std_user.obj', 'D:\\SIMULIA\\Abaqus\\6.10-1\\exec\\lbr\\standardU_static.lib', 'D:\\SIMULIA\\Abaqus\\6.10-1\\exec\\lbr\\standardB.lib', 'D:\\SIMULIA\\Abaqus\\6.10-1\\exec\\lbr\\ABQSMABasCoreUtils_import.lib', 'D:\\SIMULIA\\Abaqus\\6.10-1\\exec\\lbr\\ABQSMAAbuLicense_import.lib', '&&mt', '/manifest', 'standardU.dll.manifest', '/outputresource:standardU.dll;2', '&&', 'del', 'standardU.dll.manifest"']
 楼主| 发表于 2010-12-20 14:07:10 | 显示全部楼层 来自 安徽合肥
问题解决了 是因为fortran compiler 的license文件错误
将注册后得到的license文件拷贝到提示错误目录
下即可
谢谢各位 验证结果
Mon Dec 20 14:09:47 2010
                subroutines
                Abaqus/CFD
                3.5, or greater
Found d:\Temp\verify.  All verification files will reside in this directory.
Old job files exist.  They will be moved to verifyOLD.
Abaqus/Standard
         ...PASS
         Continuing...
         ...PASS
         Continuing...
         ...PASS
         Continuing...
         ...PASS
         Continuing...
         ...PASS
         Continuing...
         ...PASS
         Continuing...
Abaqus/Viewer
         ...PASS
         Continuing...
Abaqus/CAE
         ...PASS
         Continuing...
         ...PASS
         Continuing...
         ...PASS
         Continuing...
         ...PASS
         Continuing...
         ...PASS
         Continuing...
         ...PASS
         Continuing...
         ...PASS
         Continuing...
         ...PASS
         Continuing...
Abaqus/AMS
         ...PASS
         Continuing...
         ...PASS
         Continuing...
         ...PASS
         Continuing...
         ...PASS
         Continuing...
Abaqus/Design
         ...PASS
         Continuing...
         ...PASS
         Continuing...
         ...PASS
         Continuing...
         ...PASS
         Continuing...
         ...PASS
         Continuing...
         ...PASS
         Continuing...
         ...PASS
         ...PASS
         Continuing...
Abaqus/Foundation
         ...PASS
         Continuing...
         ...PASS
         Continuing...
Abaqus/CFD
         ...PASS
         Continuing...
Clean-up...
GMT+8, 2026-1-7 23:06 , Processed in 0.041923 second(s), 13 queries , Gzip On, MemCache On.
