查看: 398|回复: 4
[警告错误信息] win7 32位上运行abaqus子程序遇到问题请教各位高手
发表于 2010-12-21 09:13:12 | 显示全部楼层 |阅读模式 来自 上海
Problem during linking - Abaqus/Standard User Subroutines.   This error may be due to a mismatch in the Abaqus user subroutine arguments.   These arguments sometimes change from release to release, so user subroutines   used with a previous release of Abaqus may need to be adjusted.
Job ex8-3-1-1 aborted due to errors.
请问各位前辈,这个问题怎么解决,我是在cae中运行子程序时遇到这样的问题,不知如何解决,还是是因为我的c++ fortune安装有问题呢?我是xin7 32位的系统
发表于 2010-12-21 23:18:35 | 显示全部楼层 来自 美国
Had you pass the verification for C++ and Fortran? Mostly, you haven't correctly install those compiler.
 楼主| 发表于 2010-12-22 12:03:59 | 显示全部楼层 来自 上海
thank you.I have solved these problems.
发表于 2011-7-21 10:57:09 | 显示全部楼层 来自 湖南长沙
3# jialingok
请问你是如何解决的?
发表于 2011-7-27 13:25:58 | 显示全部楼层 来自 黑龙江哈尔滨
怎么解决的啊?指导一下啊 3# jialingok
GMT+8, 2026-1-2 20:05 , Processed in 0.048500 second(s), 13 queries , Gzip On, MemCache On.
