- 2012-7-8
发表于 2012-9-12 11:22:19
来自 陕西西安
版主,你好!我做网格重构时,在网格成功重构1次后,出现这样的错误提示:
| An error has occurred in cfx5solve: |
| Error reported by IO module: iif_open: the file is not in CFX-5.x |
| format |
| Error reported by IO module: iocnt: open the primary file failed |
| Error from IO module while opening |
| D:\work\CFX\large\block_002.dir\block.uns.bak: |
| "iocnt: open the primary file failed" |
| IO_BAD_FILE(20): Invalid def/res file. File could be corrupted. |
| WriteToFile failed - dataset write filed |
| The following transient and backup files written by the ANSYS CFX |
| solver have been saved in the directory |
| D:\work\CFX\large\block_002: |
| block.uns.bak, 20.trn, 15.trn |
| The results from this run of the ANSYS CFX Solver have been |
| written to D:\work\CFX\large\block_002.res |
| The following user files have been saved in the directory |
| 14_newmesh_01.mesh.log, block.blk, block.par, block.tin, |
| block.uns, boco, family_boco.fbc, hex.uns, temp.fbc, temp.fbc_old, |
| temp.uns |
能否帮我分析一下是什么原因?
我的QQ是1047218461
谢谢! |
