查看: 67|回复: 2
[结构单元] 请高手指点程序里哪里出了问题
发表于 2010-12-28 13:39:28 | 显示全部楼层 |阅读模式 来自 上海
看了论坛中关于施加刚拱架的例子,我觉得挺不错的,遂将自己的一个模拟也按照同样的方法添加进钢拱架,可是每次运行的时候,总是出现target node and source node are the same,不论怎么调间距和参数都没有用,请问,这到底是怎么回事,谢谢了!
new
gen zone radcyl p0 0 0 0 p1 50 0 0 p2 0 100 0 p3 0 0 50 &
    size 5 50 10 25 dim 6.5 6.5 6.5 6.5 rat 1 1 1 1.2 group outsiderock
plot block group
plot add axes red
gen zon reflect normal 0 0 -1
def excav
loop cut (1,13)
y0=4*cut
y1=y0+4
ys0=y0-4
ys1=y1-4
yc0=y0-2
;yc1=y1-2
h=24*(cut+1)
id_=10
command
;support the previous 4 m
sel shell id id_ range cyl end1 0 ys0 0 end2 0 ys1 0 rad 6.5 &
x -0.01 6.51 z -6.51 6.51 y ys0 ys1
sel shell id id_ prop isotropic 25e9,0.25 thickness 0.25 density 2500 range y ys0 ys1
end_command
command
sel delete link
sel set link node_tol 0.30
end_command
;beam the previous 4 m
w_y=2.00
p=13
rbeam=6.12
rshell=6.25
det=9.00
;beam半径稍小于shell(洞室)半径
       link_id=10000
       w_y=2.00
       loop m(1,p)
           loop n(31,51)
             x_shellnode=rshell*cos((n-1)*det*degrad)    ;计算rshell的节点坐标
             y_shellnode=w_y
             z_shellnode=rshell*sin((n-1)*det*degrad)
             x_beamnode=rbeam*cos((n-1)*det*degrad)      ;计算钢拱架的节点坐标
             y_beamnode=w_y                                  ;既然可以计算钢拱架的节点坐标,为什么不可以再这里定义呢?
             z_beamnode=rbeam*sin((n-1)*det*degrad)
             xx_beamnode=rbeam*cos(n*det*degrad)       ;计算钢拱架的节点坐标
             yy_beamnode=w_y
             zz_beamnode=rbeam*sin(n*det*degrad)
             if n<51 then
             command
             sel beam id 1000 beg x_beamnode y_beamnode z_beamnode end xx_beamnode,yy_beamnode,zz_beamnode
             sel beam prop emod 2e11 nu 0.3
             sel beam prop xcarea 6e-3 xciz 200e-6 xciy 200e-6 xcj 0.0
             end_command
             endif
             sn_pointer=nd_near(x_shellnode,y_shellnode,z_shellnode)
             bn_pointer=nd_near(x_beamnode,y_beamnode,z_beamnode)
             shellnode_id=nd_id(sn_pointer)
             beamnode_id=nd_id(bn_pointer)
             command
                  sel link id link_id  beamnode_id target  node  tgt_num shellnode_id
                  sel link attach  xdir=rigid ydir=rigid  zdir=rigid range id link_id
                  sel link attach  xrdir=free  yrdir=free zrdir=free range id link_id
             end_command
             link_id=link_id+1
           end_loop
        w_y=w_y+4
      end_loop
end_loop
end
excav
 楼主| 发表于 2010-12-28 14:56:48 | 显示全部楼层 来自 上海
我已经发现问题了,谢谢大家了!
发表于 2010-12-30 20:47:04 | 显示全部楼层 来自 山东青岛
sel cable id=1 beg 0,0,0 end 0,29,0 nseg 10
sel cable id=1 beg 0,29,0 end 0,35,0 nseg 6
sel cable id=1 prop emod 2e10 ytension 310e3 xcarea 0.0004906 gr_coh 1 gr_k 1 gr_per 0.0785 ran cid 1,10
sel cable id=1 prop emod 2e10 ytension 310e3 xcarea 0.0004906 gr_coh 10e5 gr_k 2e7 gr_per 0.0785 ran cid 11,17
sel delete link range id 1
sel link id=100 1 target zone
sel link attach xdir=rigid ydir=rigid zdir=rigid xrdir=rigid yrdir=rigid zrdir=rigid range id 100
sel cable id=1 pretension 60e3 range cid 1,10
提示 source node not near enough to an exiting non-null zone
啥意思?
GMT+8, 2024-5-14 08:41 , Processed in 0.035825 second(s), 13 queries , Gzip On, MemCache On.
