我想把做好的GUI转换成exe文件,但是在matlab中输入Mbuild –setup,显示如下
Warning: Could not find an exact (case-sensitive) match for 'Mbuild'.
E:\Program Files\MATLAB\R2010a\toolbox\compiler\mbuild.m is a case-insensitive match and will be
used instead.
You can improve the performance of your code by using exact
name matches and we therefore recommend that you update your
usage accordingly. Alternatively, you can disable this warning using
warning('off','MATLAB:dispatcher:InexactCaseMatch').
This warning will become an error in future releases.
E:\PROGRA~2\MATLAB\R2010A\BIN\MEX.PL: Error: '–setup' not found.
??? Error using ==> mbuild at 193
Unable to complete successfully.
貌似没有编译器让我选,我的版本是2010a,系统是64位的win7,请问该怎么解决,谢谢~~~ |
