- 2011-2-19
楼主 |
发表于 2011-3-9 11:56:05
来自 华南理工大学
2# JeffreyShi
off course
*** USER FATAL MESSAGE 4297 (EQD4D)
QUAD4 ELEMENT WITH ID =5540
HAS AN INTERIOR ANGLE POSSIBLY GREATER THAN OR EQUAL 180 DEGREES.
QUAD4 5593 86.80 67.74 135.94 0.00 0.57 ++++
QUAD4 6310 84.06 70.95 136.57 0.00 0.56 ++++
QUAD4 6395 84.59 61.39 125.70 0.00 0.53 ++++
QUAD4 6466 82.24 64.60 137.37 0.00 0.53 ++++
QUAD4 11315 79.61 72.02 135.01 0.00 0.50 ++++
QUAD4 11423 89.01 67.14 125.32 0.00 0.51 ++++
QUAD4 11434 86.95 63.03 127.95 0.00 0.53 ++++
QUAD4 11629 84.32 60.54 136.59 0.01 0.62 ++++
QUAD4 11703 82.33 58.59 125.19 0.02 0.55 ++++
QUAD4 12021 70.79 61.90 146.27 0.01 0.58 ++++
QUAD4 12026 52.44 30.96 123.53 0.05 ++++ 0.72 ++++
QUAD4 12032 46.22 28.84 ++++ 131.54 0.08 ++++ 0.49
QUAD4 12033 66.38 48.05 136.56 0.06 ++++ 0.41
QUAD4 12034 64.24 42.56 125.86 0.03 0.50 ++++
QUAD4 12145 74.29 69.36 119.06 0.00 0.59 ++++
QUAD4 12240 77.35 74.23 115.84 0.00 0.59 ++++
QUAD4 15981 82.65 80.60 95.76 0.07 ++++ 0.01
1 MARCH 9, 2011 MSC.NASTRAN 4/ 3/07 PAGE 917
0
TOLERANCE LIMITS ARE: SA = 30.00, IA(MIN) = 30.00, IA(MAX) = 150.00, WF = 0.05, TR = 0.50 (FLAG = LIMIT VIOLATED)
ELEMENT TYPE ID SKEW ANGLE MIN INT. ANGLE MAX INT. ANGLE WARPING FACTOR TAPER RATIO
QUAD4 15995 82.51 80.39 95.76 0.07 ++++ 0.01
QUAD4 18021 87.27 85.81 91.31 0.06 ++++ 0.00
QUAD4 18037 84.08 82.85 94.65 0.05 ++++ 0.01
QUAD4 18041 83.38 81.52 95.28 0.06 ++++ 0.01
QUAD4 19394 79.23 35.73 146.43 0.00 0.59 ++++
QUAD4 19430 78.94 52.95 133.34 0.01 0.64 ++++
QUAD4 20108 73.29 34.11 145.91 0.00 0.56 ++++
QUAD4 20142 72.89 34.23 145.64 0.00 0.56 ++++
QUAD4 20185 82.05 45.85 139.30 0.00 0.53 ++++
QUAD4 20682 87.29 61.70 133.04 0.02 0.59 ++++
QUAD4 20805 82.24 64.60 137.37 0.00 0.53 ++++
QUAD4 20876 84.59 61.39 125.70 0.00 0.53 ++++
QUAD4 20961 84.06 70.95 136.57 0.00 0.56 ++++
QUAD4 21678 86.80 67.74 135.94 0.00 0.57 ++++
QUAD4 21731 16.72 ++++ 14.23 ++++ 153.81 ++++ 0.00 1.00 ++++
QUAD4 ELEMENT WITH ID =21731
QUAD4 21860 71.61 47.66 117.13 0.00 0.52 ++++
QUAD4 21880 47.98 40.98 152.94 ++++ 0.00 0.48
QUAD4 21883 47.80 37.71 161.92 ++++ 0.00 0.63 ++++
QUAD4 21906 72.61 54.71 147.80 0.00 0.61 ++++
QUAD4 22003 73.68 54.51 144.41 0.00 0.58 ++++
QUAD4 22854 60.35 52.86 149.76 0.00 0.53 ++++
QUAD4 22866 62.86 51.81 147.26 0.00 0.52 ++++
QUAD4 22908 88.29 63.22 132.81 0.00 0.58 ++++
QUAD4 22913 87.26 63.25 129.30 0.00 0.55 ++++
QUAD4 22926 85.61 70.09 133.60 0.00 0.54 ++++
QUAD4 22984 82.68 73.05 94.34 0.09 ++++ 0.15
QUAD4 24054 64.68 48.56 147.51 0.00 0.51 ++++
QUAD4 24074 89.99 66.23 129.88 0.00 0.51 ++++
QUAD4 24075 58.02 29.30 ++++ 160.88 ++++ 0.00 0.59 ++++
QUAD4 24076 43.74 26.25 ++++ 170.53 ++++ 0.00 0.77 ++++
QUAD4 24077 41.79 32.35 154.22 ++++ 0.00 0.39
QUAD4 24425 59.67 50.99 129.82 0.06 ++++ 0.22
QUAD4 24571 37.22 30.94 151.15 ++++ 0.00 0.23
QUAD4 24830 87.82 65.01 126.06 0.00 0.51 ++++
QUAD4 27816 86.95 63.03 127.94 0.00 0.53 ++++
QUAD4 27827 89.01 67.14 125.32 0.00 0.51 ++++
QUAD4 27988 79.61 72.02 135.01 0.00 0.50 ++++
QUAD4 30308 62.41 43.08 149.88 0.00 0.61 ++++
QUAD4 30356 67.74 65.49 112.67 0.06 ++++ 0.06
QUAD4 30362 62.41 43.08 149.88 0.00 0.61 ++++
QUAD4 30418 67.67 65.38 113.03 0.06 ++++ 0.06
QUAD4 30593 85.78 72.80 104.77 0.00 0.58 ++++
1 MARCH 9, 2011 MSC.NASTRAN 4/ 3/07 PAGE 918
0
QUAD4 30668 84.57 61.34 125.98 0.00 0.53 ++++
QUAD4 35677 81.10 54.59 142.44 0.00 0.60 ++++
QUAD4 36477 84.32 60.54 136.59 0.01 0.62 ++++
QUAD4 36551 82.33 58.59 125.19 0.02 0.55 ++++
QUAD4 36876 64.24 42.56 125.86 0.03 0.50 ++++
QUAD4 36877 66.38 48.05 136.56 0.06 ++++ 0.41
QUAD4 36878 46.22 28.84 ++++ 131.54 0.08 ++++ 0.49
QUAD4 36882 52.44 30.96 123.53 0.05 ++++ 0.72 ++++
QUAD4 37324 85.78 72.80 104.77 0.00 0.58 ++++
QUAD4 38530 84.57 61.34 125.98 0.00 0.53 ++++
QUAD4 38563 85.21 58.78 122.14 0.00 0.51 ++++
QUAD4 39532 81.10 54.59 142.44 0.00 0.60 ++++
*** USER INFORMATION MESSAGE 7555 (GMTSTD)
FINITE ELEMENT GEOMETRY CHECK RESULTS EXCEED TOLERANCE LEVELS FOR THE FOLLOWING ELEMENTS.
A MAXIMUM OF 100 SKEW ANGLE (SA) TOLERANCE LIMIT VIOLATIONS WILL BE IDENTIFIED BY THE FLAG "++++"
PLACED AFTER THE VALUE METRIC FOR THE TEST.
A MAXIMUM OF 100 MAX INT. ANGLE (IA) TOLERANCE LIMIT VIOLATIONS WILL BE IDENTIFIED BY THE FLAG "++++"
1 MARCH 9, 2011 MSC.NASTRAN 4/ 3/07 PAGE 919
0
TOLERANCE LIMITS ARE: SKEW = 10.00, IA(MAX) = 160.00 (++++ = LIMIT VIOLATED)
ELEMENT TYPE ID SKEW ANGLE MAX INT. ANGLE
TRIA3 534 4.32 ++++ 149.39
TRIA3 535 4.63 ++++ 146.68
TRIA3 536 8.24 ++++ 128.02
TRIA3 537 8.60 ++++ 124.11
TRIA3 12144 3.08 ++++ 110.64
TRIA3 12239 3.97 ++++ 105.10
1 MARCH 9, 2011 MSC.NASTRAN 4/ 3/07 PAGE 920
0
E L E M E N T G E O M E T R Y T E S T R E S U L T S S U M M A R Y
TOTAL NUMBER OF TIMES TOLERANCES WERE EXCEEDED
ELEMENT SKEW ASPECT/ MINIMUM MAXIMUM SURFACE/FACE OFFSET EDGE POINT EDGE POINT JACOBIAN
TYPE ANGLE TAPER RATIO INTER. ANGLE INTER. ANGLE WARP FACTOR RATIO LENGTH RATIO ANGLE LIMIT DETERMINANT
QUAD4 3 75 9 15 17 N/A N/A N/A N/A
TRIA3 6 N/A N/A 0 N/A N/A N/A N/A N/A
N/A IN THE ABOVE TABLE INDICATES TESTS THAT ARE NOT APPLICABLE TO THE ELEMENT TYPE AND WERE NOT PERFORMED.
FOR ALL ELEMENTS WHERE GEOMETRY TEST RESULTS HAVE EXCEEDED TOLERANCES,
QUAD4 ELEMENT ID 533 PRODUCED SMALLEST SKEW ANGLE OF 1.77 (TOLERANCE = 30.00).
QUAD4 ELEMENT ID 5540 PRODUCED LARGEST TAPER RATIO OF 1.00 (TOLERANCE = 0.50).
QUAD4 ELEMENT ID 533 PRODUCED SMALLEST INTERIOR ANGLE OF 1.68 (TOLERANCE = 30.00).
QUAD4 ELEMENT ID 533 PRODUCED LARGEST INTERIOR ANGLE OF 179.34 (TOLERANCE = 150.00).
QUAD4 ELEMENT ID 3166 PRODUCED LARGEST WARP FACTOR OF 0.09 (TOLERANCE = 0.05).
TRIA3 ELEMENT ID 12144 PRODUCED SMALLEST SKEW ANGLE OF 3.08 (TOLERANCE = 10.00).
^^^ USER WARNING MESSAGE 9031 (ERRPH1)
^^^ NOGO ENCOUNTERED IN SUBDMAP SEMG
*** USER INFORMATION MESSAGE 4110 (OUTPX2)
END-OF-DATA SIMULATION ON FORTRAN UNIT 12
(MAXIMUM SIZE OF FORTRAN RECORDS WRITTEN = 1 WORDS.)
(NUMBER OF FORTRAN RECORDS WRITTEN = 1 RECORDS.)
(TOTAL DATA WRITTEN FOR EOF MARKER = 1 WORDS.)
1 MARCH 9, 2011 MSC.NASTRAN 4/ 3/07 PAGE 921 |
