- 2010-3-28
下面是我的程序,do循环了,但是坐标系不跟着移动,热源也就不动。期待大家的建议:
/solu
antype,trans
tunif,20 !对所有节点指定一个均布温度
kbc,1 !指定载荷为阶跃载荷
timint,on !打开瞬态效应
autots,on !自动时间步长跟踪
!选择单元加载对流条件
*dim,laserbodysource,table,11,5,1,z,x !定义激光体热源数组,11行5列1
*tread,laserbodysource,t1,txt,,0 !从t1读取数据laserbodysource
v=10/60
j=0
*do,t,1e-6,0.0002*50,0.0002
*if,j,gt,0,then
!卸载
cmsel,,lasersource !用来选中之前创建的集合,和asel等类似
bf,all,hgen,0 !BFE或BF来加载热源,hgen生热率
cmdel,lasersource
local,13,1,0,y+distance,0,,,,1,1 !distance
nsel,s,loc,x,0,Rarc !Rarc
nsel,r,loc,z,0
sfdele,all,hflux !将定义的面负载删除,hflux热流heat flux
sf,all,conv,%convection%,20 !定义节点间对流载荷
allsel
*else
allsel
*endif
j=j+1
time,100000*t !指定荷载步结束时间为t
! fcum,add !Specifies that force loads are to be accumulated
nsubst,50,,,14 !指定载荷步中需要的子步数,此荷载步的子步数为50
autots,0 !是否使用自动时间步长,0是什么意思了
deltim,,,,2 !在本载荷步中指定时间步长大小
kbc,0 !线性插值
outres,all,all !规定写入数据库的求解信息,全写入
y=v*t !不同时间时刻对应不同y,不同y处建立局部坐标系和加载热源
local,11,1,0,y,0,,,,1,1, !定义局部坐标,坐标系代号11,
nsel,s,loc,x,0,Re+remain !选取从光斑中心到Re+remain的表面节Re为光斑半径,remain=re/20
nsel,r,loc,z,0,0.0025 !选取表面到z=0.0025处节点
cm,lasersource,node !定义组元(集合)lasersource,将几何元素分组形成组元,node为组元类型
nplot
bf,all,hgen,%laserbodysource% !BFE或BF来加载热源,在节点上施加载荷
allsel
solve
! save
! finish
/solu
antype,trans,rest !读入当前最高载荷步的重启动文件
/post1
set,last !读取求解结果
etable,tmp,temp !或者ttot
esel,s,etab,tmp,150000 !melt=1000
finish
/solu
resume
*get,elemnum,elem,0,count !Number of elements in the selected set
*if,elemnum,gt,0,then
ekill,all
esel,s,live
! nsle,s,1
! nsel,invert
! d,all,all,0
*else
allsel
*endif
time,100000*t+10
allsel
solve
! /solu
! resume
! antype,trans,rest !读入当前最高载荷步的重启动文件
*enddo |
