- 22
- 2009-2-10
发表于 2011-3-25 15:34:23
来自 湖南长沙
2# demi89 看不到单元失效,但是我看了下帮助文件,看裂纹的方法是这样子的:
Then in LS-PREPOST, load the d3plot files. Under the main window, click "Mesh".
Click into the "Range" panel (among the right-hand side buttons), change the "Avg" to
"None"; and in "Set Fringe Range", choose "User" instead of the default (Dynamic) and
set the "Min:" to 0 and "Max:" to 1. Click "Update" before you leave the panel. In the
"Fcomp" panel, choose "Misc" and you'll see a "history var#1" in the "Fringe
Component" window, which should be selected for display. |
