/filename,jiechufenxi !定义文件名
/title, aim to verify solid model !定义标题
/prep7
bosongbi=0.48 !设置泊松比为全局变量
thick=0.2e-3 !设置表皮层厚度为全局变量
ET,1,PLANE183 !定义单元
KEYOPT,1,3,2 !单元选项为平面应变
MP,EX,1,1.36e5
MP,PRXY,1,bosongbi
MP,EX,2,8e4
MP,PRXY,2,bosongbi
MP,EX,3,3.4e4
MP,PRXY,3,bosongbi
MP,EX,4,2e11
MP,PRXY,4,0.3
!四种材料定义完毕
!建立模型
CSWPLA,11,1,0.75,1, !创建局部坐标系
K,1,8e-3,,, !创建关键点
K,2,-8e-3,,,
L, 2, 1
K,3,thick-8e-3,,,
K,4,-thick+8e-3,,,
K,5,-thick+7e-3,,,
K,6,thick-7e-3,,,
L, 3, 4
L, 6, 5
CSYS,0
lsymm,y,all
CSWPLA,12,1,4/5.33,1, !创建局部坐标系
k,101,2.65e-3,0
k,102,-2.65e-3,0
l,101,102
csys,0
lsymm,y,7 !建立指骨
lgen,,7,8,,,1e-3,,,,1 !向上平移1mm
nummrg,kp
WPCSYS,-1,0
RECTNG,-7e-3,7e-3,-6e-3,-7e-3
al,1,4,2,5
al,3,2,5,6
al,3,6
al,7,8
asba,4,5
aglue,2,3,6
wpoff,0,1e-3,0
wpro,,,-90
asbw,all
wpro,,-90
asbw,all
wpcsys,-1,0
alls
asel,s,loc,x,-10,0
adele,all,,,1
alls
numcmp,all
lcomb,16,22
lcomb,11,24
lcomb,10,23 !模型创建完毕
!划分网格
asel,s,area,,1,6,5
aatt,1,,1,0
asel,s,area,,3,7,4
aatt,2,,1,0
asel,s,area,,4,5,1
aatt,3,,1,0
asel,s,area,,2
aatt,4,,1,0 !赋予材料属性
lesize,12,,,4
lesize,13,,,4
lesize,3,,,4
lesize,1,,,40
lesize,2,,,40
lesize,10,,,60
lesize,11,,,60
lesize,15,,,5
lesize,6,,,5
lesize,14,,,5
lesize,16,,,60
lesize,4,,,40
lesize,19,,,15
lesize,21,,,15
lesize,20,,,15
lesize,17,,,40
lesize,18,,,60
lesize,5,,,4
lesize,9,,,4
lesize,7,,,20
lesize,8,,,20
alls
mshape,0
mshkey,1
amesh,all !网格划分完毕
!设置接触对
/COM, CONTACT PAIR CREATION - START
MAT,1
R,3 !定义接触实常数
REAL,3
ET,2,169 !定义接触单元类型
ET,3,172
KEYOPT,3,5,1
KEYOPT,3,10,2
R,3,0,0,0.1, 0,1e-008,0
! Generate the target surface
LSEL,S,,,8
CM,_TARGET,LINE
TYPE,2
NSLL,S,1
ESLN,S,0
ESURF,all
! Generate the contact surface
LSEL,S,,,10
CM,_CONTACT,LINE
TYPE,3
NSLL,S,1
ESLN,S,0
ESURF,all
cmdel,_TARGET
cmdel,_CONTACT
ALLSEL,all
Eplot
ESEL,S,TYPE,,2
ESEL,A,TYPE,,3
ESEL,R,REAL,,3
/PSYMB,ESYS,1
/PNUM,TYPE,1
/NUM,1
EPLOT
finish !接触对创建完毕
!进入求解器
/solu
antype,0
nlgeom,1
nsubst,100,200,20
outres,all,all
eqslv,spar
lnsrch,1
pred,on,,on
time,2
NROPT,FULL, ,OFF
!施加约束
allsel,all
lplot
dl,9,,symm
dl,12,,symm
dl,13,,symm
dl,14,,symm
dl,15,,symm
dl,19,,symm
dl,20,,symm
dl,17,,all,0
dl,18,,all,0
dl,7,,uy,2e-3
solve !求解 |
