- 2010-12-2
C THE ABAQUS USER SUBROUTINE UMAT FOR GRADED ELEMENTS IS PRESENTED HERE. IT IS WRITTEN IN FORTRAN LANGUAGE.
C
C PROBLEM DESCRIPTION
C THIS UMAT USER SUBROUTINE IS FOR ISOTROPIC AND ISOTHERMAL MATERIALS.
C THIS SUBROUTINE HANDLES FOR 3-D AND PLANE STRAIN PROBLEMS.
C THIS SUBROUTINE NEEDS TO BE MODIFED FOR PLANE STRESS.
C BOTH HOMOGENEOUS AND GRADED PROPERTIES ARE POSSIBLE BY SELECTING
C APPROPRIATE FUNCTIONAL FORM OF "PROPS".
C THIS UMAT IS BASED ON "DIRECT INTEGRATION METHOD".
C IMPORTANT NOTICE
C FOR NEW PROBLEMS, CHOOSE THE FUNCTION FOR
C THE MATERIAL VARIATION AND THE VALUES OF "PROPS".
C AFTER THAT, GO TO THE SECTION -CHANGE- AND CHANGE THE FUNCTION AND
C VALUES ACCORDINGLY.
C ------------------------------------------------------------------------------------------------------------------------C
SUBROUTINE UMAT (STRESS,STATEV,DDSDDE,SSE,SPD,SCD,
1 RPL,DDSDDT, DRPLDE, DRPLDT,
2 STRAN,DSTRAN,TIME,DTIME,TEMP,DTEMP,PREDEF,DPRED,CMNAME,
3 NDI,NSHR,NTENS,NSTATV,PROPS,NPROPS,COORDS,DROT,PNEWDT,
4 CELENT,DFGRD0,DFGRD1,NOEL,NPT,LAYER,KSPT,KSTEP,KINC)
C
INCLUDE 'C:\SIMULIA\ABAQUS\6.9-1\SITE\ABA_PARAM_DP.INC'
C
CHARACTER*8 CMNAME
DIMENSION STRESS(NTENS),STATEV(NSTATV),DDSDDE(NTENS,NTENS),
1DDSDDT(NTENS),DRPLDE(NTENS),
2STRAN(NTENS),DSTRAN(NTENS),TIME(2),PREDEF(1),DPRED(1),
3PROPS(NPROPS),COORDS(3),DROT(3,3),DFGRD0(3,3),DFGRD1(3,3)
C
C DETERMINE MATERIAL PROPERTIES BASED ON GLOBAL COORDINATES OF GAUSS POINTS.
C COORDS (1) IS X-COORDINATE OF GAUSS POINTS.
C COORDS (2) IS Y-COORDINATE OF GAUSS POINTS.
C COORDS (3) IS Z-COORDINATE OF GAUSS POINTS.
C PROPS IS DESIGNED BY USERS.
C THE FUNCTION CAN BE ALSO DESIGNED BY USERS.
C----CHANGE ------------------------------------------------------------------------------------------------------------------------------------------------------
C PROPS(1)-----E(0)
C PROPS(2)-----(E(h)-E(0))/h
C V=0.3
E=PROPS(1)+PROPS(2)*(COORDS(2)-1)
C ----------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------
C DETERMINE LAME'S CONSTANTS
C MU IS MU
C ALAMBDA IS LAMBDA
AMU=E/2.0D0/(1.0D0+0.3)
ALAMBDA=E*0.3/(1.0D0+0.3)/(1.0D0-2.0D0*0.3)
C DETERMINE THE TANGENT(JACOBIAN) MATRIX
C NDI IS NUMBER OF NORMAL STRESSES (E.G. SXX, SYY, SZZ)
C NSHR IS NUMBER OF SHEAR STRESSES(E.G. SXY)
C NTENS IS DIMENSION OF CONSTITUTIVE MATRIX (NTENS=NDI+NSHR)
DO I=1, NDI
DO J=1, NDI
IF (I.EQ.J) THEN
C 定义主对角线元素
DDSDDE(I,I)=ALAMBDA+2.0D0*AMU
ELSE
DDSDDE(I,J)=ALAMBDA
ENDIF
ENDDO
ENDDO
DO I=NDI+1, NTENS
DDSDDE(I,I)=AMU
ENDDO
C DETERMINE THE STRESS AND UPDATE THE STRESS
DO I=1, NTENS
DO J=1, NTENS
STRESS(I)=STRESS(I)+DDSDDE(I,J)*DSTRAN(J)
ENDDO
ENDDO
RETURN
END
这个子程序试用于动力计算分析吗?希望各位大侠指点! |
