查看: 65|回复: 1
高手帮忙,运行matlab程序得出部分结果后,出了下面第错误提示,不知道是什么原因
发表于 2011-4-28 10:48:54 | 显示全部楼层 |阅读模式 来自 上海
我的防火墙中已经设置matlab可以访问网络,同时网络连接断开
我的程序见附件!
谢谢!
       Segmentation violation detected at Thu Apr 28 11:10:00 2011
Configuration:
  MATLAB Version:   7.1.0.246 (R14) Service Pack 3
  MATLAB License:   161051
  Operating System: Microsoft Windows 2000
  Window System:    Version 6.0 (Build 6000)
  Processor ID:     x86 Family 6 Model 7 Stepping 6, GenuineIntel
  Virtual Machine:  Java 1.5.0 with Sun Microsystems Inc. Java HotSpot(TM) Client VM mixed mode
  Default Charset:  GBK
Register State:
  EAX = 0000001c  EBX = cbf79292
  ECX = 0000001f  EDX = 0000001c
  ESI = cbf79291  EDI = 40000000
  EBP = 00000000  ESP = 00cda78c
  EIP = 0fcb2f21  FLG = 00210292
Stack Trace:
This error was detected while a MEX-file was running.  If the MEX-file
is not an official MathWorks function, please examine its source code
for errors.  Please consult the External Interfaces Guide for information
on debugging MEX-files.
If it is an official MathWorks function, please
follow these steps in reporting this problem to The MathWorks so
that we have the best chance of correcting it:
  1. Send this crash report to segv@mathworks.com for automated analysis.
     For your convenience, this information has been recorded in:
       C:\Users\nwh\AppData\Local\Temp\matlab_crash_dump.9264
  2. Also, if the problem is reproducible, send the crash report to
     support@mathworks.com along with:
       - A specific list of steps that will reproduce the problem
       - Any M, MEX, MDL or other files required to reproduce the problem
       - Any error messages displayed to the command window
     A technical support engineer will contact you with further information.
Thank you for your assistance.  Please save your workspace and restart
MATLAB before continuing your work.
Error in ==> maple at 104
[result,status] = maplemex(statement);
Error in ==> sym.maple at 85
[result,status] = maple(statement);
Error in ==> sym.inv at 26
   [X,stat] = maple('inverse',A);
Error in ==> bysj at 107
          b=b-inv(a1s)*f1s;
发表于 2011-4-28 15:19:21 | 显示全部楼层 来自 黑龙江哈尔滨
呵呵,第一次看见现在还有用Windows 2000的。可能是你用符号工具箱了吧,Matlab混合编程不支持。
GMT+8, 2024-10-4 16:35 , Processed in 0.038044 second(s), 13 queries , Gzip On, MemCache On.
