- 2009-10-17
楼主 |
发表于 2011-5-16 10:04:41
来自 福建泉州
******* notice ******** notice ******** notice ********
contracting memory to 20280
expanding memory to 146780
expanding memory to 273200
expanding memory to 415412
expanding memory to 460412
expanding memory to 490412
expanding memory to 917672
*** Warning blank line where command expected Check near line # 64
(This is line# 64 of file
F:\GDUB\gdub.dyn)
expanding memory to 979972
expanding memory to 1004478
Open include file: gdub.blk
Open include file: gdub.mod
expanding memory to 1330009
expanding memory to 1360614
expanding memory to 1391219
expanding memory to 1413921
expanding memory to 1436623
expanding memory to 1459325
expanding memory to 1551140
expanding memory to 1573842
expanding memory to 1604447
expanding memory to 2706235
expanding memory to 3178096
expanding memory to 3208701
expanding memory to 3231403
expanding memory to 3254105
LS-DYNA will perform a structural only analysis
GDUB
ls-dyna (version 970 ) date 01/10/2005
*** Warning reset D3PLOT ouput interval from 0. to 5.2500E-04
expanding memory to 2773
expanding memory to 17896
expanding memory to 211090
expanding memory to 1912076
expanding memory to 1942661
expanding memory to 2537108
expanding memory to 2539139
expanding memory to 2540495
expanding memory to 2562885
expanding memory to 2565886
expanding memory to 2632883
expanding memory to 2632885
expanding memory to 2908836
contracting memory to 2869086
expanding memory to 3055749
expanding memory to 3792668
expanding memory to 3861133
expanding memory to 4421280
expanding memory to 4489386
expanding memory to 4730070
contracting memory to 4730070
expanding memory to 4730150
expanding memory to 4730158
contracting memory to 4730158
expanding memory to 4730162
contracting memory to 4730162
expanding memory to 4852582
master surface has 14346 segments, 0 renumbered
slave surface has 1910 segments, 0 renumbered
master surface has 13499 segments, 0 renumbered
master surface has 850 segments, 0 renumbered
*** Warning element ID 32643 has a zero normal vector.
*** Error, element ID 32643 has a zero AREA stop.
E r r o r t e r m i n a t i o n
Memory required for explicit solution : 4852582
Additional dynamically allocated memory: 107831
Total: 4960413
T i m i n g i n f o r m a t i o n
CPU(seconds) %CPU Clock(seconds) %Clock
Initialization ....... 0.0000E+00 0.00 0.0000E+00 0.00
Element processing ... 0.0000E+00 0.00 0.0000E+00 0.00
Binary databases ..... 0.0000E+00 0.00 0.0000E+00 0.00
ASCII database ....... 0.0000E+00 0.00 0.0000E+00 0.00
Contact algorithm .... 0.0000E+00 0.00 0.0000E+00 0.00
Contact entities ..... 0.0000E+00 0.00 0.0000E+00 0.00
Rigid bodies ......... 0.0000E+00 0.00 0.0000E+00 0.00
Implicit Nonlinear ... 0.0000E+00 0.00 0.0000E+00 0.00
Implicit Lin. Alg. ... 0.0000E+00 0.00 0.0000E+00 0.00
T o t a l s 0.0000E+00 0.00 0.0000E+00 0.00
Problem time = 0.0000E+00
Problem cycle = 0
Total CPU time = 0 seconds ( 0 hours 0 minutes 0 seconds)
CPU time per zone cycle = 0 nanoseconds
Clock time per zone cycle= 0 nanoseconds
Number of CPU's 1
NLQ used/max 96/ 96
Start time 05/16/2011 09:36:21
End time 05/16/2011 09:36:25
Elapsed time 4 seconds ( 0 hours 0 minutes 4 seconds)
E r r o r t e r m i n a t i o n |
