- 43
- 2003-1-14
发表于 2011-6-14 02:03:32
来自 澳大利亚
Well done. JingheSu,总结得很好,更难得是的这份热心和慷慨。
对于经常需要用EXCEL或ORIGIN,MATLAB作图和数据分析的,不妨试试matplotlib。
http://matplotlib.sourceforge.net/
我再鼓吹一下MATPLOTLIB, 有点跑题了,离楼主的帖子远了点,算是灌水了
考几个例子:
(1)- from pylab import *
- def f(t):
- s1 = cos(2*pi*t)
- e1 = exp(-t)
- return multiply(s1,e1)
- t1 = arange(0.0, 5.0, 0.1)
- t2 = arange(0.0, 5.0, 0.02)
- t3 = arange(0.0, 2.0, 0.01)
- subplot(211)
- l = plot(t1, f(t1), 'bo', t2, f(t2), 'k--', markerfacecolor='green')
- grid(True)
- title('A tale of 2 subplots')
- ylabel('Damped oscillation')
- subplot(212)
- plot(t3, cos(2*pi*t3), 'r.')
- grid(True)
- xlabel('time (s)')
- ylabel('Undamped')
- show()
复制代码
(2)图上加公式!- from matplotlib import rcParams
- rcParams['text.usetex']=True
- rcParams['text.latex.unicode']=True
- from numpy import arange, cos, pi
- from matplotlib.pyplot import figure, axes, plot, xlabel, ylabel, title, \
- grid, savefig, show
- figure(1, figsize=(6,4))
- ax = axes([0.1, 0.1, 0.8, 0.7])
- t = arange(0.0, 1.0+0.01, 0.01)
- s = cos(2*2*pi*t)+2
- plot(t, s)
- xlabel(r'\textbf{time (s)}')
- ylabel(ur'\textit{Velocity (\u00B0/sec)}', fontsize=16)
- title(r"\TeX\ is Number $\displaystyle\sum_{n=1}^\infty\frac{-e^{i\pi}}{2^n}$!",
- fontsize=16, color='r')
- grid(True)
- show()
复制代码
(3) 更多
http://matplotlib.sourceforge.net/gallery.html
matplotlib和PYTHON很优美,不过很多时候我还是EXCEL VBA+ORIGIN痛并快乐着(放弃旧的搞新的好难...) |
