- 2010-10-2
各位同仁好!向大家请教这个问题,如何解决!谢谢了先!
Abaqus Product Install Verification...
Fri Jun 10 23:43:23 2011
Running system requirement checks.
Requirement: Windows XP, Windows Server 2003 Standard Edition, or Windows
Vista
Product: All Abaqus Products
Status: Pass - Found Microsoft Windows Vista Home Basic Home Edition
Service Pack 2 (Build 6002).
Requirement: Microsoft Visual C++ 8.0 (.NET 2005)
Product: Abaqus make utility with C++
Status: Pass - Found Microsoft Visual C++ 8.0.50727.42.
Requirement: Intel Fortran Compiler 9.1 or 10.1
Product: Abaqus make utility with Fortran and Abaqus with user
subroutines
Status: Fail - Unable to locate or determine the version of a
Fortran compiler on this system. If Intel Fortran is
installed on this machine, please load ifortvars.bat before
running Abaqus.
Requirement: Internet Explorer 6.0, Mozilla 1.2, Firefox 1.0.1, or
greater
Product: Abaqus Documentation
Status: Fail - Found 360安全浏览器 3.6.1.2.
Found D:\SIMULIA\verify. All verification files will reside in this
directory.
Old job files exist. They will be moved to verifyOLD.
Abaqus/Standard
...PASS
Continuing...
Abaqus/Standard with user subroutines
...INFORMATION
System requirements were not met. Verification
procedure will be skipped. However, user subroutines
can be run using a precompiled library set by the
variable usub_lib_dir. For more information please
see the section 3.2.2 of Abaqus Analysis User's
Manual.
Continuing...
Abaqus/Explicit (single precision)
...PASS
Continuing...
Abaqus/Explicit (double precision)
...PASS
Continuing...
Abaqus/Explicit with user subroutines (single precision)
...INFORMATION
Manual.
Continuing...
Abaqus/Explicit with user subroutines (double precision)
...INFORMATION
Manual.
Continuing...
Abaqus/Viewer
...PASS
Continuing...
Abaqus/CAE
...PASS
Continuing...
Geometry Translator for CATIA V4
...PASS
Continuing...
Geometry Translator for CATIA V5
...PASS
Continuing...
Direct Geometry Import for CATIA V5
...PASS
Continuing...
Geometry Translator for I-DEAS
...PASS
Continuing...
Geometry Translator for Parasolid
...PASS
Continuing...
Geometry Translator for Pro/ENGINEER
...PASS
Continuing...
SolidWorks Associative Interface
...PASS
Continuing...
Abaqus/AMS
...PASS
Continuing...
Abaqus Interface for MSC.ADAMS
...PASS
Continuing...
Abaqus/Standard parametric studies
...PASS
Continuing...
Abaqus/Explicit parametric studies
...PASS
Continuing...
Abaqus/Design
...PASS
Continuing...
Abaqus Interface for Moldflow
...PASS
Continuing...
...INFORMATION
Continuing...
...PASS
Continuing...
Abaqus make utility with object code
...PASS
Continuing...
Abaqus scripting interface
...PASS
Continuing...
Abaqus analyses using parallelization
Running thread-based parallel with 2 cpu(s)
Abaqus/Explicit domain-level parallel
...PASS
Abaqus/Standard direct solver
...PASS
Continuing...
Abaqus/Foundation
...PASS
Continuing...
Abaqus noGUI (CAE/Viewer)
...PASS
Continuing...
Clean-up...
Verification directory D:\SIMULIA\verify has been deleted. |
