- 22
- 2010-10-7
发表于 2011-6-17 08:24:15
来自 河北秦皇岛
Driver | Contour Display | The X11 driver (screen display) and raster mode | You can display a maximum of nine contours, no matter how many contours the /CONTOUR command specifies. | The X11 driver (screen display) and raster mode | You can display more than nine contours, but the number of contours displayed will be rounded down to the next lowest multiple of nine. For example, if you specify 20 contours, the program displays only 18 contours. In addition, if you specify more than nine contours, contour colors will not be unique (that is, you might have two or more adjacent contour lines with the same color). | The X11C driver (screen display) in either vector or raster mode | If eight graphic planes are available, you can specify any number of contours, up to 128. If your display device does not support eight graphic planes, you are limited to displaying nine contours. If another process has used some of the colors, making fewer than eight graphic planes available, you cannot display more than nine contours. (To verify how many graphic planes are available, issue the /PSTATUS command after a plot command.) To make more graphic planes available, you must exit from the ANSYS program, re-enter, and then issue the /SHOW,X11C-FORC to force selection of the full set of eight graphic planes. | Plotting to an ANSYS neutral graphics file | Nine contours are the maximum, unless you specify the contour range (using VMIN and VMAX in the /CONTOUR command), or unless you explicitly set NCPL to 8 on the /SHOW command). |
