查看: 402|回复: 3
求高手解决下
发表于 2011-7-12 16:45:36 | 显示全部楼层 |阅读模式 来自 四川成都
我做HyperXtrude里自带的HX_0002.hm例子里,做到了Step 4: Suppress extraneous edges on the part,但是Step 5做不来了,我现在分成的几个实体都在lvl3这个component里面,杂个把不同的部分放到不同的component里面去。(我目前做到的样子在附件里)
教程里是这样的:
Step 5: Rename the components
1.From the Collectors menu, select Rename.
2.Go to the individually sub-panel.
3.Verify the entity type is set to comps.
4.Click original name = and select the component lvl1, from the list of components.
5.Click once in the new name = field to highlight its text.
6.Type Billet.
7.Repeat steps 4 through 6, and rename the component lvl2 to Portholes.
8.Repeat steps 4 through 6, and rename the component lvl3 to Bearing.
9.Repeat steps 4 through 6, and rename the component lvl4 to Profile.
Step 6: Organize the components
1.From the Geometry menu, select Organize and then select Solids.
2.Verify the entity type is set to solids.
3.Select solids, and select the solid region in the graphics window that represents the billet portion of the geometry.
4.Click dest = and select Billet.
5.Click
move.
6.Repeat steps 3 through 5 and organize the solid geometry as shown below.
Model organization of solid entities
 楼主| 发表于 2011-7-14 20:02:12 | 显示全部楼层 来自 四川成都
看来使用hx的人太少了,我正在整理在网上找到的资料,整理好就给大家发出来。。。。。。。。。。。
发表于 2011-8-23 11:19:54 | 显示全部楼层 来自 湖南长沙
用organize命令移动体到不同的component就ok了
发表于 2016-2-20 19:29:28 | 显示全部楼层 来自 江苏苏州
有大神教我这个徒弟吗   q1579261204
GMT+8, 2026-1-2 20:04 , Processed in 0.029594 second(s), 13 queries , Gzip On, MemCache On.
