- 2010-7-27
分析时,以前都是好好,可能对abaqus系统文件不是很了解,对于这个问题不知如何解决 有望大侠指点 谢谢
The executable D:\Program Files\abaqus\6.10-1\exec\standard.exe aborted with system error code 144. Please check the .dat, .msg, and .sta files for error messages if the files exist. If there are no error messages and you cannot resolve the problem, please run the command "abaqus job=support information=support" to report and save your system information. Use the same command to run Abaqus that you used when the problem occurred. Please contact your local Abaqus support office and send them the input file, the file support.log which you just created, the executable name, and the error code. |
