查看: 48|回复: 3
出现错误提示“??? Unable to find subsindex function for class cell.”
发表于 2011-7-20 23:24:00 | 显示全部楼层 |阅读模式 来自 湖北武汉
Error in ==> D:\MATLAB6p5\work\utilities\VA1Demo.m (update_object_list)
On line 46  ==> eval(strcat('class_id = ',handles.commandname(selected,:),';'));
Error in ==> D:\MATLAB6p5\work\utilities\VA1Demo.m (VA1Demo_OpeningFcn)
On line 122  ==> update_object_list(hObject,handles);
Error in ==> D:\MATLAB6p5\toolbox\matlab\uitools\gui_mainfcn.m
On line 141  ==>     feval(gui_State.gui_OpeningFcn, gui_hFigure, [], guidata(gui_hFigure), varargin{:});
On line 33  ==>     gui_mainfcn(gui_State, varargin{:});
错误提示如上所示,求解。恳请高手和热心人士帮助啊。
 楼主| 发表于 2011-7-21 09:04:47 | 显示全部楼层 来自 湖北武汉
1# whutmemory 自己先顶一下。在网上看到说是由于变量名和matlab已有的函数名相同才出现这种错误,但是看了半天不知道哪个变量名冲突了。
 楼主| 发表于 2011-7-21 09:13:51 | 显示全部楼层 来自 湖北武汉
2# whutmemory
Subject:Why do I receive the error message: "??? Unable to find subsindex function for class char"?
Problem Description:??? Unable to find subsindex function for class char
??? Unable to find subsindex function for class struct
In MATLAB 6.1 and previous versions, I can reproduce this error message using the following code:
set='abc'
set(gcf,'position')
Solution:This error occurs when a variable has the same name as a MATLAB function. For example, this error would occur if a variable in my MATLAB code was named SET, which is also a MATLAB function.
To determine if a particular variable is also a MATLAB function, you can use the which -all command. For example:
which set -all
If it outputs both a variable name and a filename that is under the MATLAB path, then you will need to rename your variable.
这是mathworks的官网找到的。不知class cell和class char有什么区别。
发表于 2012-1-6 15:11:16 | 显示全部楼层 来自 河北廊坊
请你给出具体的代码,以方便调试
GMT+8, 2024-7-8 08:31 , Processed in 0.030775 second(s), 11 queries , Gzip On, MemCache On.
