ADINA-T data input file D:\adina\温度场和应力场耦合冻胀\1月份冻胀温度场.dat successfully updated.
***WARNING: No element connection for node 1912 temperature DOF
No element connection for node 1913 temperature DOF
No element connection for node 1914 temperature DOF
No element connection for node 1915 temperature DOF
No element connection for node 1916 temperature DOF
No element connection for node 1917 temperature DOF
No element connection for node 1918 temperature DOF
No element connection for node 1919 temperature DOF
No element connection for node 1920 temperature DOF
No element connection for node 1921 temperature DOF
No element connection for node 1922 temperature DOF
No element connection for node 1923 temperature DOF
No element connection for node 1924 temperature DOF
No element connection for node 1925 temperature DOF
No element connection for node 1926 temperature DOF
No element connection for node 1927 temperature DOF
No element connection for node 1928 temperature DOF
No element connection for node 1929 temperature DOF
No element connection for node 1930 temperature DOF
No element connection for node 1931 temperature DOF
No element connection for node 1932 temperature DOF
No element connection for node 1933 temperature DOF
No element connection for node 1934 temperature DOF
No element connection for node 1935 temperature DOF
No element connection for node 1936 temperature DOF
No element connection for node 1937 temperature DOF
No element connection for node 1938 temperature DOF
No element connection for node 1939 temperature DOF
No element connection for node 1940 temperature DOF
No element connection for node 1941 temperature DOF
No element connection for node 1942 temperature DOF
No element connection for node 1943 temperature DOF
No element connection for node 1944 temperature DOF
No element connection for node 1945 temperature DOF
No element connection for node 1946 temperature DOF
No element connection for node 1947 temperature DOF
No element connection for node 1948 temperature DOF
No element connection for node 1949 temperature DOF
No element connection for node 1950 temperature DOF
No element connection for node 1951 temperature DOF
No element connection for node 1952 temperature DOF
No element connection for node 1953 temperature DOF
No element connection for node 1954 temperature DOF
No element connection for node 1955 temperature DOF
No element connection for node 1956 temperature DOF
No element connection for node 1957 temperature DOF
No element connection for node 1958 temperature DOF
No element connection for node 1959 temperature DOF
No element connection for node 1960 temperature DOF
No element connection for node 1961 temperature DOF
Message limit reached - above message has been suppressed 60 times.
Nodal degrees of freedom without element
connection have been fixed for ADINA-T input data.
There may still be degrees of freedom without
stiffness - see documentation.
