--ANSYS中24种材料属性-绝对值得一看
Isotropic Elastic: High Carbon Steel
MPMOD,1,1
MP,ex,1,210e9! Pa
MP,nuxy,1,.29! No units
MP,dens,1,7850! kg/m3
Orthotropic Elastic: Al203
MPMOD,1,2
MP,ex,1,307e9! Pa
MP,ey,1,358.1e9! Pa
MP,ez,1,358.1e9! Pa
MP,gxy,126.9e9! Pa
MP,gxz,126.9e9! Pa
MP,gyz,126.9e9! Pa
MP,nuxy,1,.20! No units
MP,nuxz,1,.20! No units
MP,nuyz,1,.20! No units
MP,dens,1,3750! kg/m3
Anisotropic Elastic: Cadmium
MPMOD,1,3
MP,dens,3400! kg/m3
TB,ANEL,1
TBDATA,1,121.0e9! C11 (Pa)
TBDATA,2,48.1e9! C12 (Pa)
TBDATA,3,121.0e9! C22 (Pa)
TBDATA,4,44.2e9! C13 (Pa)
TBDATA,5,44.2e9! C23 (Pa)
TBDATA,6,51.3e9! C33 (Pa)
TBDATA,10,18.5! C44 (Pa)
TBDATA,15,18.5! C55 (Pa)
TBDATA,21,24.2! C66 (Pa)
Blatz-Ko: Rubber
MPMOD,1,5
MP,gxy,1,104e7! Pa
Mooney-Rivlin: Rubber
MPMOD,1,8
MP,dens,1,.0018! lb/in3
MP,nuxy,1,.499! No units
TB,MOONEY,1
TBDATA,1,80! C10 (psi)
TBDATA,2,20! C01 (psi)
Viscoelastic: G-11 Glass
MPMOD,1,18
MP,dens,1,2390! kg/m3
TB,EVISC,1
TBDATA,46,27.4e9! Go (Pa)
TBDATA,47,0.0! (Pa)
TBDATA,48,60.5e9! Bulk modulus (Pa)
TBDATA,61,.53! 1/
Bilinear Isotropic Plasticity: Nickel Alloy
MPMOD,1,6
MP,ex,1,180e9! Pa
MP,nuxy,1,.31! No units
MP,dens,1,8490! kg/m3
TB,BISO,1
TBDATA,1,900e6! Yield stress (Pa)
TBDATA,2,445e6! Tangent modulus (Pa)
Transversely Anisotropic Elastic Plastic: 1010 Steel
MPMOD,1,10
MP,ex,1,207e9! Pa
MP,dens,1,7845! kg/m3
TB,PLAW,,,,7
TBDATA,1,128.5e6! Yield stress (Pa)
TBDATA,2,202e5! Initial strain at failure
TBDATA,3,1.41! r-value
TBDATA,4,1! Yield stress vs. plastic strain curve (see EDCURVE below)
Strain(1) = 0,.05,.1,.15,.2
YldStres(1)=207e6,210e6,214e6,218e6,220e6 ! yield stress
EDCURVE,ADD,1,Strain (1),YldStres(1)
Rate Sensitive Powerlaw Plasticity: A356 Aluminum
MPMOD,1,17
MP,ex,1,75e9! Pa
MP,nuxy,1,.33! No units
MP,dens,1,2750! kg/m3
TB,PLAW,,,,4
TBDATA,1,1.002! k (MPa)
TBDATA,2,.7! m
TBDATA,3,.32! n
TBDATA,4,5.0! Initial strain rate (s-1)
Plastic Kinematic: 1018 Steel
MPMOD,1,19
MP,ex,1,200e9! Pa
MP,nuxy,1,.27! No units
MP,dens,1,7865! kg/m3
TB,PLAW,,,,1
TBDATA,1,310e6! Yield stress (Pa)
TBDATA,2,763e6! Tangent modulus (Pa)
TBDATA,4,40.0! C (s-1)
TBDATA,5,5.0! P
TBDATA,6,.75! Failure strain
Bilinear Kinematic Plasticity: Titanium Alloy
MPMOD,1,33
MP,ex,1,100e9! Pa
MP,nuxy,1,.36! No units
MP,dens,1,4650! kg/m3
TB,BKIN,1
TBDATA,1,70e6! Yield stress (Pa)
TBDATA,2,112e6! Tangent modulus (Pa)
Powerlaw Plasticity: Aluminum 1100
MPMOD,1,21
MP,ex,1,69e9! Pa
MP,dens,1,2710! kg/m3
TB,PLAW,,,,2
TBDATA,1,0.598! k
TBDATA,2,0.216! n
TBDATA,3,6500.0! C (s-1)
TBDATA,4,4.0! P
3 Parameter Barlat Plasticity: Aluminum 5182
MPMOD,1,22
MP,ex,1,76e9! Pa
MP,nuxy,1,.34! No units
MP,dens,1,2720! kg/m3
TB,PLAW,,,,3
TBDATA,1,1! Hardening rule of 1 (yield stress)
TBDATA,2,25e6! Tangent modulus (Pa)
TBDATA,3,145e6! Yield stress (Pa)
TBDATA,4,0.170! Barlat exponent, m
TBDATA,5, .73! R00
TBDATA,6,.68! R45
TBDATA,7,.65! R90
TBDATA,8,0! CSID
Barlat Anisotropic Plasticity: 2008-T4 Aluminum
MPMOD,1,23
MP,ex,1,76e9! Pa
TB,PLAW,,,,6
TBDATA,1,1.04! k (MPa)
TBDATA,2,.65! Initial strain at failure
TBDATA,3,.254! n
TBDATA,4,11! Barlat exponent, m
TBDATA,5, 1.017! a
TBDATA,6,1.023! b
TBDATA,7,.9761! c
TBDATA,8,.9861! f
TBDATA,9,.9861! g
TBDATA,9,.8875! h
Strain Rate Dependent Plasticity: 4140 Steel
MPMOD,1,24
MP,ex,1,209e9! Pa
TB,PLAW,,,,5
TBDATA,1,1! LCID yield stress vs. strain rate (see first EDCURVE command below)
TBDATA,2,22e5! Tangent modulus (Pa)
TBDATA,3,2! LCID Elastic modulus vs. strain rate (see second EDCURVE command below)
StrnRate(1) = 0,.08,.16,.4,1.0
YldStres(1) = 207e6,250e6,275e6,290e6,300e6
ElasMod(1) = 209e9,211e9,212e9,215e9,218e9
EDCURVE,ADD,1,StrnRate(1),YldStres(1)
EDCURVE,ADD,2,StrnRate(1),ElasMod(1)
Piecewise Linear Plasticity: High Carbon Steel
MPMOD,1,28
MP,ex,1,207e9! Pa
MP,nuxy,1,.30! No units
MP,dens,1,7830! kg/m3
TB,PLAW,,,,8
TBDATA,1,207e6! Yield stress (Pa)
TBDATA,3,.75! Failure strain
TBDATA,4,40.0! C (strain rate parameter)
TBDATA,5,5.0! P (strain rate parameter)
TBDATA,6,1! LCID for true stress vs. true strain (see EDCURVE below)
TruStran(1)=0,.08,.16,.4,.75
TruStres(1)=207e6,250e6,275e6,290e6,3000e6
EDCURVE,ADD,1,TruStran (1),TruStres(1)
Johnson-Cook Linear Polynomial EOS: 1006 Steel
MPMOD,1,30
MP,ex,1,207e9! Pa
TB,EOS,1,,,1,1
TBDATA,1,350.25e6! A (Pa)
TBDATA,2,275e6! B (Pa)
TBDATA,3,.36! n
TBDATA,4,.022! c
TBDATA,5,1.0! m
TBDATA,6,1400! Melt temperature (oC)
TBDATA,7,30! Room temperature (oC)
TBDATA,8,10! Initial strain rate
TBDATA,9,4500! Specific heat
TBDATA,10,240e6! Failure stress
TBDATA,11,-.8! Failure value D1
TBDATA,12,2.1! Failure value D2
TBDATA,13,-.5! Failure value D3
TBDATA,14,.0002! Failure value D4
TBDATA,15,.61! Failure value D5
TBDATA,17,20e5! EOS linear polynomial term
Johnson-Cook Gruneisen EOS: OFHC Copper
MPMOD,1,31
MP,ex,1,138e9! Pa
MP,nuxy,1,.35! No units
MP,dens,1,8330! kg/m3
TB,EOS,1,,,1,2
TBDATA,1,89.63e6! A (Pa)
TBDATA,2,291.64e6! B (Pa)
TBDATA,3,.31! n
TBDATA,4,.025! c
TBDATA,5,1.09! m
TBDATA,6,1200! Melt temperature (oC)
TBDATA,9,4400! Specific heat
TBDATA,11,-.54! Failure value D1
TBDATA,12,4.89! Failure value D2
TBDATA,13,-3.03! Failure value D3
TBDATA,14,.014! Failure value D4
TBDATA,15,1.12! Failure value D5
TBDATA,16,.394! C
TBDATA,17,1.489! S1
TBDATA,18,0.0! S2
TBDATA,19,0.0! S3
TBDATA,20,2.02! 0
TBDATA,21,.47! A
Null Material Linear Polynomial EOS: Brass
MPMOD,1,32
MP,ex,1,200e9! Pa
MP,nuxy,1,.3! No units
MP,dens,1,7500! kg/m3
TB,EOS,1,,,2,1
TBDATA,1,0.0! Pressure cut-off
TBDATA,3,1.5! Relative volume in tension
TBDATA,4,.7! Relative volume in compression
TBDATA,17,16e5! EOS linear polynomial
Null Material Gruneisen EOS: Aluminum
MPMOD,1,29
MP,ex,1,100e9! Pa
MP,dens,1,2500! kg/m3
TB,EOS,1,,,2,2
TBDATA,1,-10000! Pressure cut-off (Pa)
TBDATA,3,2.0! Relative volume in tension
TBDATA,4,.5! Relative volume in compression
TBDATA,16,.5386! C
TBDATA,17,1.339! S1
TBDATA,18,0.0! S2
TBDATA,19,0.0! S3
TBDATA,20,1.97! 0
TBDATA,21,.48! A
Rigid Material: Steel
MPMOD,1,7
MP,ex,1,207e9! Pa
MP,dens,1,7580! kg/m3
EDMP,rigid,1,7,7
Cable Material: Steel
MPMOD,1,27
MP,ex,1,207e9! Pa
EDMP,cable,1,1! See EDCURVE below
EngStran(1) = .02,.04,.06,.08
EngStres(1) = 207e6,210e6,215e6,220e6
EDCURVE,ADD,1,EngStran (1),EngStres(1)
Transversely Anisotropic FLD: Stainless Steel
MPMOD,1,54
MP,ex,1,30e6! Pa
MP,dens,1,.00285! kg/m3
TB,PLAW,1,,,10
TBDATA,1,20e3! Initial yield stress (Pa)
TBDATA,2,5000! Tangent modulus (Pa)
TBDATA,3,.2! Hardening parameter
TBDATA,5,1! Maximum yield stress curve (see EDCURVE below)
mnstrn(1) = -30,-10,0,20,40,50
mjstrn(1) = 80,40,29,39,45,44
EDCURVE,ADD,1,mnstrn (1),mjstrn(1)
Steinberg Gruneisen EOS: Stainless Steel
MPMOD,1,52
MP,gxy,1,11.16e6! (Pa)
MP,dens,1,.285! (kg/m3)
TB,EOS,1,,,5,2
TBDATA,1,49.3e3! Initial yield stress (Pa)
TBDATA,2,43! Hardening coefficient
TBDATA,3,.35! n
TBDATA,5,.36e6! Maximum yield stress (Pa)
TBDATA,10,32! Atomic weight
TBDATA,11,2380! Absolute melting temp.
TBDATA,15,2! Spall type
TBDATA,16,1! Cold compression energy flag
TBDATA,17,-50! Min. temp. parameter
TBDATA,18,200! Max. temp. parameter
TBDATA,29,.457! C
TBDATA,30,1.49! S1
TBDATA,31,0.0! S2
TBDATA,32,0.0! S3
TBDATA,33,1.93! 0
TBDATA,34,1.4! A
4340钢的johnson-cook参数及其grunesion状态方程
$Define Steel 4340
*MAT_JOHNSON_COOK
1, 7.8400E+00, 0.759E-00, 2.000E+00, 0.320E+00, 0.000E+00
0.793E-02, 0.510E-02, 2.60E-01, 1.400E-02, 1.030E+00, 1.793E+03, 2.930E+02, 1.000E-05
4.400E-06, 2.000E-02, 2.000E+00, 0.000E+00, 0.80E+00, 2.100E+00, -0.05E+00, 2.000E-03
0.610E+00
*EOS_GRUNEISEN
1, 4.578E-01, 1.330E+00, 0.000E+00, 0.000E+00, 1.670E+00, 0.430E+00, 0.000E+00
1.000E+00
$ SI unit :cm-g-microsecond
$ unit conversion factor
$ 1 psi=6895 pa, 1 dyn=1e-5 n,1 bar=1e5 pa,1 g/cm**3=0.0361 lb/in**3,1 lb=0.454kg |
