- 35
- 2004-10-23
发一个自己编的采用有限单元法计算温度场的例子
温度描述:一个杆件,半径为2in,长度为9in,左边的温度为200F,周围环境的温度为0F,杆件的导热率KXX=3 Btu/(h-in-F),杆件同周围环境的换热系数为h=1.0 Btu/(h-in2-F).
所有的几何条件可以作为变量输入,有限元的划分份数也可以自己控制。结果文件在output文件中。
program heatone
use imsl
implicit none
real tempend,tempsur,kxx,htran,radis
real len,elelen,danlen,area,xishuqian,kyoubu(2,2),forceyou(2),hpl
real eledanyuan(2,2),forcedanyuan(2)
integer num,i,j
real,allocatable::tempzong(,output(:,
real,allocatable::eleduo1(:,,eleduo2(:,,eleduo(:,,forceduo(
real,allocatable::elezong(:,,forcezong(
integer,allocatable::dingwei(:,
!在这个例子中,长度的单位是in
len=9.0
radis=2.0
area=(radis)**2.0*3.14
kxx=3.0
htran=1.0
tempsur=0.0
tempend=200.0
num=9
allocate(tempzong(num+1),eleduo1(2*num,2),eleduo2(2*num,2),forceduo(2*num),dingwei(num,2))
allocate(elezong(num+1,num+1),forcezong(num+1),output(num+1,2),eleduo(2*num,2))
elelen=len/(num*1.0)
danlen=len/num
xishuqian=area*kxx/danlen
hpl=htran*2*3.14*(radis)*danlen/6.0
do i=1,num
eleduo1(2*i-1,1)=xishuqian
eleduo1(2*i-1,2)=xishuqian*-1
eleduo1(2*i,1)=xishuqian*-1
eleduo1(2*i,2)=xishuqian
eleduo2(2*i-1,1)=hpl*2.0
eleduo2(2*i-1,2)=hpl
eleduo2(2*i,1)=hpl
eleduo2(2*i,2)=hpl*2.0
eleduo(2*i-1,1)=eleduo1(2*i-1,1)+eleduo2(2*i-1,1)
eleduo(2*i-1,2)=eleduo1(2*i-1,2)+eleduo2(2*i-1,2)
eleduo(2*i,1)=eleduo1(2*i,1)+eleduo2(2*i,1)
eleduo(2*i,2)=eleduo1(2*i,2)+eleduo2(2*i,2)
enddo
do i=1,2
do j=1,2
kyoubu(i,j)=0.0
enddo
enddo
!下面的部分是将kyoubi集成到总刚里面
kyoubu(2,2)=htran*area
eleduo(2*num-1,1)=eleduo(2*num-1,1)+kyoubu(1,1)
eleduo(2*num-1,2)=eleduo(2*num-1,2)+kyoubu(1,2)
eleduo(2*num,1)=eleduo(2*num,1)+kyoubu(2,1)
eleduo(2*num,2)=eleduo(2*num,2)+kyoubu(2,2)
do i=1,num
forceduo(2*i-1)=0.0
forceduo(2*i)=0.0
enddo
forceyou(1)=0.0
forceyou(2)=htran*area*tempsur
!下面的部分是将forceyou集成到总单元荷载里面
forceduo(2*num-1)=forceduo(2*num-1)+forceyou(1)
forceduo(2*num)=forceduo(2*num)+forceyou(2)
do i=1,num,1
dingwei(i,1)=i
dingwei(i,2)=i+1
enddo
do i=1,num+1,1
do j=1,num+1,1
elezong(i,j)=0.0
forcezong(i)=0.0
tempzong(i)=0.0
enddo
enddo
do i=1,num,1
eledanyuan(1,1)=eleduo(2*i-1,1)
eledanyuan(1,2)=eleduo(2*i-1,2)
eledanyuan(2,1)=eleduo(2*i,1)
eledanyuan(2,2)=eleduo(2*i,2)
forcedanyuan(1)=forceduo(2*i-1)
forcedanyuan(2)=forceduo(2*i)
elezong(dingwei(i,,dingwei(i,)= elezong(dingwei(i,,dingwei(i,)+eledanyuan
forcezong(dingwei(i,)= forcezong(dingwei(i,)+forcedanyuan
enddo
!下面开始求解方程
write(*,100) elezong
100 format(4f10.6)
pause 1
write(*,200) forcezong
200 format(1f10.5)
pause 1
elezong(1,1)=10**5*elezong(1,1)
!注意不能重复乘第二次了
forcezong(1)=elezong(1,1)*tempend
tempzong=(elezong).ix. (forcezong)
do i=1,1+num,1
output(i,1)=(i-1.0)*danlen
output(i,2)=tempzong(i)
enddo
open(4,file='c:/nongdu.txt')
write(4,50) transpose(output)
close(4)
50 format(2f10.4)
write(*,300) tempzong
300 format(1f10.4)
pause 1
end program |
