- 64
- 2003-3-10
发表于 2009-6-14 14:52:26
来自 加拿大
Here is a APDL code use the *MFOURIER function.
The original code is from: http://ansys.net/?mycat=search&mytype=Macros&mycategory=PostProc
There is another code named FFTDFT there for FFT in ANSYS, basically it rewrite the FFT code in ANSYS APDL.
Below is the source code:
C*****************************************************************************
C*** MACRO fxfrm08.mac, BILL BULAT, 12/11/96
C*** PRODUCES FOURIER XFORM OF TIME DOMAIN RESPONSE. RESULTING FOURIER
C*** COEFFICIENTS ARE READ INTO A POST26 VARIABLE (EVEN TERMS => REAL PART,
C*** ODD TERMS => IMAGINARY PART) AND AMPLITUDE IS PLOTTED VS FREQUENCY.
C*** UTILIZES ANSYS [*MFOURIER] COMMAND.
C******************************************************************************
C*** MACRO USEAGE:
C*** fxfrm08, IR, IA, IB, FREQBEG, FREQEND
C***
C*** IR = RESULT VAR NUM TO WHICH FOUR COEFFICIENTS WILL BE WRITTEN
C*** IA = VAR NUM CONTAINING DISCRETE TRANS RESPONSES
C*** IB = VAR NUM WILL BE FILLED WITH FREQUENCIES TO WHICH COEFFICIENTS
C*** IN IR CORRESPOND (THIS IS FOR PLOTTING).
C*** FREQBEG = BEGINNING FREQUENCY OF PLOT
C*** FREQEND = HIGHEST FREQ FOR WHICH FOURIER COEFFICIENTS SHALL BE
C*** EVALUATED.
C*** USE FOLLOWING LINES ONLY IN GUI IMPLEMENTATION
*if,_z1,gt,0.5,then
C*** EVALUATE pi
*afun,rad
pi = 4*atan(1)
C*** DETERMINE # OF STORED TIME PTS, FINAL TIME
*get,n,vari,,nsets
*get,tfinal,vari,1,extr,vlast
dim = arg5*tfinal+1 *** DIMENSION FOR ARRAYS BASED ON MAX FREQ & tfinal
*if,dim,ge,n/2,then
dim = nint((n-2)/2)
*elseif,dim,le,1,then
dim = nint((n-2)/2)
*else
dim = nint(dim)
*endif
C*** ZERO OUT VAR# arg1 (IR)
filldata,arg1,1,n,1,0,0
C*** FILL VAR# arg3 (IB) WITH FREQUENCIES CORRESPONDING TO ck's
C*** THESE ARE 0,1/Tf,2/Tf,3/Tf,...
filldata,arg3,1,1,1,0
filldata,arg3,2,n,1,1/tfinal,1/tfinal
C*** DIMENSION ARRAYS FOR USE WITH *MFOURIER COMMAND
*get,dfnd,parm,mode,type
*if,dfnd,gt,-1,then
mode(1)=
*endif
*get,dfnd,parm,isym,type
*if,dfnd,gt,-1,then
isym(1)=
*endif
*get,dfnd,parm,theta,type
*if,dfnd,gt,-1,then
theta(1)=
*endif
*get,dfnd,parm,f_of_t,type
*if,dfnd,gt,-1,then
f_of_t(1)=
*endif
*get,dfnd,parm,ck,type
*if,dfnd,gt,-1,then
ck(1)=
*endif
*get,dfnd,parm,zero,type
*if,dfnd,gt,-1,then
zero(1)=
*endif
*dim,mode,,2*dim
*dim,isym,,2*dim
*dim,theta,,n
*dim,f_of_t,,n
*dim,ck,,2*dim
*dim,zero,,n
C*** FILL ARRAYS FOR USE WITH *MFOURIER COMMAND
*vfil,mode(1),ramp,0,1
*vfil,mode(dim+1),ramp,0,1
*vfil,isym(1),ramp,1,0
*vfil,isym(dim+1),ramp,-1,0
vget,theta(1),1 *** READ TIME (VAR 1) INTO ARRAY theta
*vfac,360/tfinal *** NORMALIZE theta TO 360 DEG (FOR *MFOU)
*vop,theta(1),theta(1),add
vget,f_of_t(1),arg2
*vfil,zero(1),ramp,0,0
C*** ZERO OUT REAL & IMAG PARTS OF VAR# arg1 (IR) FOR BEFORE
C*** FILLING WITH NEW DATA
vput,zero(1),arg1,0,0 *** PUT REAL PART INTO VAR ARG1
vput,zero(1),arg1,0,1 *** PUT IMAG PART INTO VAR ARG1
C*** USE [*MFOURIER] COMMAND TO CALCULATE FOURIER COEFFICIENTS
*mfou,fit,ck(1),mode(1),isym(1),theta(1),f_of_t(1)
!*vfil,ck(dim+1),ramp,0
C*** PUT COEFFICIENTS (FREQ RESPONSES) INTO VAR# arg1
vput,ck(1),arg1,0,0 *** PUT REAL PART INTO VAR ARG1
vput,ck(dim+1),arg1,0,1 *** PUT IMAG PART INTO VAR ARG1
C*** ZERO OUT REAL PART OF VAR# arg1 (IR) FOR n > dim+1
C*** ([VPUT] CMD ERRONEOUSLY FILLS THIS PART OF VARIABLE @5.3)
filldata,arg1,dim+2,n,1,0,0
C*** PLOT RESPONSES vs FREQUENCY
xvar,arg3
plcp,0
/axl,x,FREQ
/axl,y,FOURIER XFORM
*if,arg5,ne,0,then
/xra,arg4,1*arg5
*else
/xra,arg4,dim/tfinal
*endif
plvar,arg1
/axl,x
/axl,y
xvar,1
plcp,2
/xra
C*** FOLLOWING LINES FOR CHECKING PUPOSES ONLY
C*** TEMPORARY CALCULATION OF AMPLITUDE (VAR#5) TO DETERMINE TIME OF MAX AMPL
realvar,5,3,,,real2
imagin,6,3,,,imag2
prod,5,5,5
prod,6,6,6
add,6,5,6
sqrt,5,6,,,ampl2
C*** FOLLOWING LINES FOR CHECKING PURPOSES ONLY
C*** REPORT REAL & IMAG COMPONENTS OF FXFRM @ MAX AMPLITUDE
!*get,scrapt,vari,5,extrem,tmax
!*get,scrapr,vari,3,rtime,scrapt
!*get,scrapi,vari,3,itime,scrapt
!*msg,ui,scrapr,scrapi
!real part: %G %/ imag part: %G
*elseif,_z1,eq,0.5,then
*msg,ui
No time-history data to make Fourier Transform of.&
Create time-history plot first.
*endif |
