- 1
- 2011-6-4
大家好,我做的一个回弹分析,不收敛 并且报错,信息翻译大概是软件系统报错,我用俩台计算机计算,都是这样报错。而且每个增量不都非常小,大约在10e-10或e-14方左右。
算到80多步的时候开始报错, inp的文件重启动文件和message 我都已经上穿到公共邮箱 请那文高手帮我下,我改怎么解决。第一次遇到 太棘手了。谢谢
公共邮箱:abaqus163@163.com 密码:abaqus
这是错误信息:
The executable D:\ABAQUS 6.10\6.10-1\exec\standard.exe aborted with system error code 5. Please check the .dat, .msg, and .sta files for error messages if the files exist. If there are no error messages and you cannot resolve the problem, please run the command "abaqus job=support information=support" to report and save your system information. Use the same command to run Abaqus that you used when the problem occurred. Please contact your local Abaqus support office and send them the input file, the file support.log which you just created, the executable name, and the error code.
message警告信息:
**WARNING: ELEMENT 9903 INSTANCE X-1 HAS VANISHINGLY SMALL THICKNESS
**WARNING: ELEMENT 9904 INSTANCE X-1 HAS VANISHINGLY SMALL THICKNESS
**WARNING: ELEMENT 9905 INSTANCE X-1 HAS VANISHINGLY SMALL THICKNESS
**WARNING: ELEMENT 10125 INSTANCE X-1 HAS VANISHINGLY SMALL THICKNESS
**WARNING: ELEMENT 10129 INSTANCE X-1 HAS VANISHINGLY SMALL THICKNESS
**WARNING: ELEMENT 10130 INSTANCE X-1 HAS VANISHINGLY SMALL THICKNESS
**WARNING: ELEMENT 10131 INSTANCE X-1 HAS VANISHINGLY SMALL THICKNESS
**WARNING: ELEMENT 10132 INSTANCE X-1 HAS VANISHINGLY SMALL THICKNESS
**WARNING: ELEMENT 10133 INSTANCE X-1 HAS VANISHINGLY SMALL THICKNESS
**WARNING: THE STRAIN INCREMENT HAS EXCEEDED FIFTY TIMES THE STRAIN TO CAUSE
FIRST YIELD AT 1428 POINTS
**WARNING: THE STRAIN INCREMENT IS SO LARGE THAT THE PROGRAM WILL NOT ATTEMPT
THE PLASTICITY CALCULATION AT 1413 POINTS
**WARNING: EXCESSIVE DISTORTION OR EXCESSIVE ROTATION OF THE NORMAL IN 160
SHELL ELEMENTS
