查看: 300|回复: 6
【原创】请教关于梁的简单问题
发表于 2003-8-9 15:37:51 | 显示全部楼层 |阅读模式 来自 浙江舟山
对于梁,二维,线弹性,
问题1  如果我默认,在x轴上建了一个梁,那么1-axils和2-axis组成的平面就是y-z平面,那么1-axils和2-axils分别指那条?在处理梁的问题中,这里有什么需要注意的嘛?
问题2  如果section采用general
那么输入了面积,和IZ后
第二行空
第三行给一个弹性模量是否还需要其他常数(在ansys中还需要一个h)
问题3  在给梁加压力的时候,我采用
*dload
1,py,100 是否就是指没单位长度梁加压力100,还是指加单位力(两者方想不一样),也就是说,那句命令是否需要写成
1,py,-100
期待您的关注和伸手:)
发表于 2003-8-9 18:03:38 | 显示全部楼层 来自 上海
回复: 【原创】请教关于梁的简单问题
问题1和2:
Data lines for SECTION=GENERAL:
First line:
1. Area, .
2. Moment of inertia for bending about the 1-axis, .
3. Moment of inertia for cross bending, .
4. Moment of inertia for bending about the 2-axis, .
5. Torsional rigidity, .
6. Sectoral moment, . (Only needed in ABAQUS/Standard when the section is associated with open-section beam elements.)
7. Warping constant, . (Only needed in ABAQUS/Standard when the section is associated with open-section beam elements.)
Second line (optional; enter a blank line if the default values are to be used):
1. First direction cosine of the first beam section axis.
2. Second direction cosine of the first beam section axis.
3. Third direction cosine of the first beam section axis.
The entries on this line must be (0, 0, -1) for planar beams. The default for beams in space is (0, 0, -1) if the first beam section axis is not defined by an additional node in the element's connectivity. See ``Beam element cross-section orientation,'' Section 15.3.4 of the ABAQUS/Standard User's Manual and Section 14.3.4 of the ABAQUS/Explicit User's Manual, for details.
因此在CAE中要指定梁的方向。
Third line:
1. Young's modulus, .
2. Torsional shear modulus, . (Not used for beams in a plane.)
3. Coefficient of thermal expansion.
4. Temperature.
5. First field variable.
6. Second field variable.
7. Etc., up to four field variables.
Subsequent lines (only needed if the DEPENDENCIES parameter has a value greater than four):
1. Fifth field variable.
2. Etc., up to eight field variables per line.
Repeat this set of data lines as often as necessary to define the properties as a function of temperature and other predefined field variables.
3、如果是压力,应该不用指明方向,1,py,100 即可。
 楼主| 发表于 2003-8-9 19:52:35 | 显示全部楼层 来自 浙江舟山
回复: 【原创】请教关于梁的简单问题
大侠,上面那段help我也查过,只是有一点不明白的地方
就是1,2,3。。那些参数是不是一定都要填上,比如说我分析
与温度无关,也需要tempeature?我想肯定对于一些简单的分析
有的不需要吧?比如对于我图中这样一个简单问题,只给了这几个
常数,连波松比都没有,那么应该填入多少东西哪?
还有关于梁的方向的问题,那一段也是有点看不明白,是不是第二行
定义的方向决定了第一行中的1axils,2axils到底是那条轴?那他说的
方向余弦是哪两个角底方向余弦?
因为是新手,所以有些缠不清,呵呵,望在点拨一下
发表于 2003-8-9 20:59:05 | 显示全部楼层 来自 上海
回复: 【原创】请教关于梁的简单问题
第二行定义的方向即决定了1-axial,对于平面问题,即为(0,0,-1),即Z的负轴方向;在Y-Z平面上,1-axial的方向决定了,那么2-axial自然就确定了,即Y轴方向了。
不用的参数当然不必填,你这个问题我试着写一下:
*BEAM GENERAL SECTION
50.65, 7892
0, 0, -1
30.0E6,
 楼主| 发表于 2003-8-9 21:56:29 | 显示全部楼层 来自 浙江舟山
回复: 【原创】请教关于梁的简单问题
我用下面的程序
*heading
ansys vm2 beam stresses and deflections
*node
1,0,0,0
2,120,0,0
3,240,0,0
4,360,0,0
5,480,0,0
*element,type=b21,elset=beam
1,1,2
2,2,3
3,3,4
4,4,5
*beam general section,SECTION=general,ELSET=BEAM
50.65,7892,
0,0,-1
30e6
*step
*static
*boundary
2,pinned
4,2
*dload
1,py,-833.33
4,py,-833.33
*node print
u,rf,
*el print
s,
*end step
发现有一个问题
1 在加压力那一会,我还是采用-833.33
问题3 在给梁加压力的时候,我采用
*dload
1,py,-100
因为如果压力是从下面往上呀,那也还是压力,那么显然方向应该和原来有区别,所以加分布力,方向还是要和整体坐标系一致,是嘛,也就是*dload加的
是分布力而不能说是压力
2 结果输出有节点信息(和理论值一致),但是没有单元的应力值,这是为什么?还缺什么语句?还是这个单元不行?
发表于 2003-8-9 22:34:34 | 显示全部楼层 来自 上海
回复: 【原创】请教关于梁的简单问题
首先,不好意思的是:I,将*dload看成*dsload了,后者才是压力;
其次,在运行你的Inp文件后可以看到dat文件中有一个警告,即:
  ***WARNING: OUTPUT REQUEST S11 IS NOT AVAILABLE FOR ELEMENT TYPE B21 UNLESS
             *SECTION POINTS IS SPECIFIED AS PART OF THE *BEAM GENERAL SECTION
             DEFINITION
我想你应该能够明白这个意思了吧?因为用*beam general section定义的梁截面形状是不定的,梁截面各处的应力是不一样的,所以必须指定输出应力的位置坐标,具体看参见帮助。
另外,指出一点:你的边界条件最好应该定义到Model data中而不是History data模块中,当然你这样对结果不会有什么影响,但不太规范。
修改后:
*heading
*node
1,0,0,0
2,120,0,0
3,240,0,0
4,360,0,0
5,480,0,0
1,1,2
2,2,3
3,3,4
4,4,5
50.65,7892,
0,0,-1
30e6
*SECTION POINTS
Local -position of first section point, Local -position of first section point,
*boundary
2,pinned
4,2
*step
*static
*dload
1,py,-833.33
4,py,-833.33
*node print
u,rf,
*el print, POSITION=AVERAGED AT NODES, SUMMARY=YES
s,
*end step
 楼主| 发表于 2003-8-9 22:47:08 | 显示全部楼层 来自 浙江舟山
回复: 【原创】请教关于梁的简单问题
多谢大侠指点,受益非浅
GMT+8, 2024-9-30 16:11 , Processed in 0.060693 second(s), 13 queries , Gzip On, MemCache On.
