- 2014-5-13
发表于 2014-6-1 17:27:49
来自 河北石家庄
我生成网格后弄了一个网格零件,如果建立面集合的话是不是要选择所有的单元呢?还有我把网格加密后下午算的出来切屑了但是到一半就停止啊,错误是The executable Program aborted with system error code 65535. Please check the .dat, .msg, and .sta files for error messages if the files exist. If there are no error messages and you cannot resolve the problem, please run the command "abaqus job=support information=support" to report and save your system information. Use the same command to run Abaqus that you used when the problem occurred. Please contact your local Abaqus support office and send them the input file, the file support.log which you just created, the executable name, and the error code.这个该咋解决呢大神 |
