- 1
- 2002-12-2
楼主 |
发表于 2003-11-7 08:33:11
来自 江苏无锡
回复: 【讨论】CFX的朋友快来
I add " MSCP_PROE_CMD=" the full path of pro/E""in the file cfx5launcher.cfg located C:\Documents and Settings\user\Application Data\CFX-5, does not show MSCP_PROE_CMD=" the full path of pro/E" after operating the command show/variables in the main menu. and adding " MSCP_PROE_CMD=" the full path of pro/E"" in the system enviroment variables , shows the " MSCP_PROE_CMD=" the full path of pro/E"" in CFX, but can`t run the import for Pro/E. I suggest you are right or the configuration file of the CFX import for Pro/e is not cfx5launcher.cfg.
dou you use the softerware cfx, I have downloaded some .ppt documents about CFX ,if you need I Email to you, or you access the URL:http://www.aoxue.org/cgi-bin/bbs/forum_show.cgi,there is a column about the CFX.hope it benefits you . |
